07-27-2011, 04:04 AM | #11 |
60
Rep 508
PM sent!
08 135i N54
- Vargas Stage 1 Turbos with Billet wheels - BMS Intake, BMS Charge pipe, AR DPs, Stock mids, berk race muffler delete - JB4 G5 Map 3 75 Meth Additive with RACE DME flash - MS-109 and 100% meth injection (Single CM12 nozzle) |
07-27-2011, 08:04 AM | #12 |
Zooombie attaaack!!
136
Rep 1,179
07-28-2011, 12:22 AM | #14 |
Rep 39
Why is it the pdf install shows the tank tapped differently than yours? Looks like yours doesn't have the float switch in the bottom. Seriously considering this, just want to make sure EVERYTHING is there
07-28-2011, 12:03 PM | #15 |
Zooombie attaaack!!
136
Rep 1,179
I have the float switch, you can see it in the picture showing all the parts. I think my float switch is slightly different than the one they had when making the diy but it works the same. I didn't use it because I figured I could just be cautious with the meth level, and I was right, but it is really easy to put in if you want to use it.
