07-12-2011, 03:59 AM | #1 |
Save the Manuals
1714
Rep 2,937
check your diff for slow leak
I recently had the LSD fluid changed to Redline and the Indy shop noticed it wet around the input shaft seal ---- a common thing on the Var. M diff. lock? see this thread....E46fans M3 forum
There has never been one drop on the garage floor. Not one. Should I pay for seal surgery or just top it off regularly? The car is low mileage and the diff fluid was full when it was changed out. Anyone else see this yet on their M? Anyone change seals only to see it seep again?
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
07-12-2011, 05:17 AM | #2 |
423
Rep 5,329
mine isnt??? 10k miles and being used to deploy 450rwhp......
i hope this isnt something thats going to keep needing replacement, i track and use my car hard pretty much everytime i drive it also.......
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
07-12-2011, 08:16 AM | #3 |
55
Rep 844
I had a very small amount of diff fluid on the input shaft when I was changing my diff fluid to Redline. I wiped it off with a paper towel about 4000 miles ago. Just checked it and its still dry.
07-12-2011, 04:07 PM | #4 | |
Save the Manuals
1714
Rep 2,937
i'll have to check it tonight
2023 G80 6MT, CCBs
07-12-2011, 04:29 PM | #5 |
Dog Listener
704
Rep 7,850
Mine is nice and dry after the repair work was done (and that's with three track days on top of some normal driving).
07-16-2011, 01:48 AM | #7 |
Save the Manuals
1714
Rep 2,937
Inspected under the car tonight. The area is not dripping or wet, so I think it's a non-issue. The service guys think the LSD was overfilled prior and that caused the excess fluid to find it's way out. With the correct level of Redline, it is good to go.
2023 G80 6MT, CCBs
07-16-2011, 01:56 AM | #8 |
218
Rep 4,726
After 100k miles you still wouldn't have low fluid. Ignore it, or have it fixed if you want (and possibly make more problems by doing so)
07-17-2011, 09:29 PM | #9 |
Save the Manuals
1714
Rep 2,937
Thanks for your input. Are you a mechanic by chance? You sure know your stuff
2023 G80 6MT, CCBs
