07-09-2011, 05:03 AM | #1 |
37
Rep 223
MDM....Have you tried this??
hi all
I'm finding the DSC cuts in far too often and was wondering how people have found the car with MDM mode on? I belive MDM partially turns off the safety net within DSC and allows slip. I dont want to get a nasty surprise so want to know your experiences with it and whether the slip is easily controllable! |
07-09-2011, 06:18 AM | #2 |
625
Rep 1,333
Drove at Goodwood circuit in dry with switched off. Grip is very strong and with it switched off power is pretty instant out of corners etc. Car is very controllable a joy to drive. Have also done the same on the road again I prefer it switched off however clearly a lot more risk !!
07-09-2011, 06:23 AM | #3 | |
26
Rep 401
Drives: 2011 Saphire Black 1M Coupé
If you can drive a rwd car, MDM is not much of a challenge, even in the rain. If you lack the experience, train with it first. The car has so much grunt, that the rear can step out in the wet in fourth, if you hit a bump wrong and are pushing hard. Even with MDM the DSC will take over at some point, but you can get angles of up to 45° (just my guess, haven't meassured). So if you don't have the experience as far as counter steering, etc. goes... train, train, train before you touch the button!
The best piece of road - worldwide.
07-09-2011, 07:29 AM | #4 |
37
Rep 223
the UK roads can be quite bumpy with frequent camber changes and the DSC was reigning in the power too often.
thanks guys for the feedback. I will try driving with MDM activated and see how the car responds knowing that DSC will help if I overstep the mark. |
07-09-2011, 09:47 AM | #5 |
112
Rep 1,140
Does anyone know if the LSD is somehow connected or in relationship with the MDM mode, or not ?
As in "when the LSD is active, and MDM is not active for sportier driving, the electronics will cut on engine power." I observed that I get frequent power cuts when driving public roads, coming out of a real slow and real tight corner. All my electronis are ON when driving public roads, and the ESP cuts in regularly in coming out of corners. So wondering if this is related to the LSD noticing different wheel rotation speeds, and if this would happen less frequent with MDM mode. Last edited by hwelvaar; 07-09-2011 at 10:08 AM.. |
07-09-2011, 09:52 AM | #6 | |
71
Rep 485
07-09-2011, 10:27 AM | #7 |
79
Rep 1,421
MDM simply gives the traction control a little more freedom before it steps in. It isn't nearly as turned down as I would like. Don't think you are going to turn MDM on and suddenly have the car drifting around corners. It's nicer than having DSC on but it still has BMW Legal written all over it. I'd like to make MDM allow a lot more pitch angle before it intervenes and the tuner I'm working with is looking into it.
On track MDM was hardly different from leaving the electronics on. It was only when I shut it off completely that the car would really go full hooligan.
Dan Parker
07-09-2011, 10:55 AM | #8 | ||
191
Rep 4,848
Just need to put to where you want to go and let the electronics do the work. As far as I know "Full" counter steering in MDM only can be done on the new M5. I will have more play in the morning, but the few times I got caught with the back stepping out with MDM on, the car has already adjusted itself by the time I realised I have lost my rears.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange Last edited by sparoz; 07-09-2011 at 12:02 PM.. |
07-09-2011, 02:46 PM | #9 |
79
Rep 1,421
"I will have more play in the morning, but the few times I got caught with the back stepping out with MDM on, the car has already adjusted itself by the time I realised I have lost my rears."
Well said. Once you get used to MDM you can almost ignore the loss of grip and keep the throttle open, knowing the silicone is going to step in.
Dan Parker
07-10-2011, 01:18 PM | #10 |
Rep 188
Drives: 1M / M3 E36 3.2 6MT
To my experiece, MDM is kicking in quite early if you open the throttle, especially on some bumps. It's more reacting to wheel slip than reacting to yaw angles. However, MDM allows reasonable yaw angles if your driving style is more accurately described by "balancing your car through the corners" instead of "forcing the car into the corners".
As a former E36 M3 owner (321PS, no DSC at all) I prefer DSC off in the dry and MDM in the wet ... or when I'm not prepared to "surprises" |
07-10-2011, 06:13 PM | #11 | |
54
Rep 254
Drives: 2020 Bmw 228xi Gran Coupe
holly |
07-11-2011, 02:13 AM | #12 |
26
Rep 401
@hwelvaar: The DSC monitors a lot of things. Among them is wheel spin (as it is also responsible for traction control). Since a lsd will always transfer torque to the wheel that provides more grip, that will cause a difference in rotation speeds (usually the inner wheel will spin), in a corner, that alone is obviously enough to make the DSC cut the power when left in stock mode. So yes, the two are connected, and no, the DSC does not control the lsd. The lsds basic principal is that of a hydraulic lsd.
@The "let the DSC do its job" comments: One thing one has to realize... the DSC may not even register, that a cars rear end has stepped out. The classic noob driver error is aquaplaning while the cruise control is engaged. The rear steps out very slowly, the DSC does not register. The cruise control registers a loss in speed and accelerates. The car will do the exact opposite of what one should do (countersteer and engage the clutch). And the same thing is true, when driving the car on the edge. You can create situations where the DSC will cause the rear end to step out and you can create situations where the DSC will not even register, that the rear end has moved. I have not yet experienced a situation, where the DSC created a "tank slapper" because I counter steered. I wouldn't know why that should happen... to me that's an urban legend. The car will kick out to the other side, if I "over-countersteer". Simple physics, has nothing to do with the DSC. To the assistance systems in general: One has to realize, that the driver is basically doing something wrong, if the system engages. Powersliding is not the fastest way out of a corner, so the system is correct, if it trys to maximize traction. A driver that knows what he/she is doing can drive with MDM on on a racetrack and the system will not engage. DSC off allows more show... not necessarily more speed, if the track I'm running on doesn't just consist of hairpins.
07-11-2011, 02:33 AM | #13 |
Resident Kerbalnaut
477
Rep 10,703
Yes and no. A certain amount of slippage does allow you to drive a bit faster.
But as far as pinning the throttle and letting it go of course the traction control will kick in. My stock motored 135 can cause that light to kick in up to 3rd gear at times...I don't know what your 1Ms will do but I can imagine that it will at least match that. |
07-11-2011, 03:42 AM | #14 |
Rep 72
Hello, on my exp, MDM allows more wheelspin and angle so the lsd have the opportunity to be of use. If you let the dsc on, the power is cutted far sooner than the time when you'll feel the benefit of the lsd. But when mdm is on, it's far more agressive out of corners, or into it. It allowed me some drifting angle, but I was on busy road going sideways was not indicated. As Dan Parker said, even on mdm, you still get massive powercuts, and it'll take me some skills to fully feel the car and get the max of it. But damn, it's so fast in second after a sharp turn! The torque rush is the most challenging part to keep it straight.
Eat my dust ///::....
07-11-2011, 05:31 AM | #16 | |
///Mbassador
26
Rep 1,069
Regarding the statement above that, when using the intermediate setting, careful balancing through corners will maintain a moderate drift more than a heavy handed throw it in approach - what appears to be a delayed onset of intervention may be a little illusory in that by being smoother you are simply taking longer to start to drift. The moment of intervention in response to a particular attitude of the car is still the same. My own experience so far with traction control turned fully off, ( given that I have yet to run the car in so I haven't explored the limits - yet ) finds that the car seems to respond better to a more aggressive style than a gentle style. Particularly the front end, which will push wide unless I aggressively load the front outside tyre, then it can be balanced on the throttle quite nicely with very quick responses. This may change dramatically on a track at race type speeds requiring a subtler approach of course but given that 99.99999999% of my driving is street and back roads that may be irrelevant to me. I'm still playing with tyre pressures though it seems that the standard pressures are pretty close to the mark, though I'm not sure that I like the Michelin PS2s tendency to slip-grip-slip-grip. Or is that just the way I'm driving? I suspect that this car is similar to the M3s in that it really comes into its' own at the sort of speeds that will land me in a lot of trouble one day. Last edited by gazz; 07-11-2011 at 05:49 AM.. Reason: Grammer |
07-11-2011, 10:15 AM | #17 |
Resident Kerbalnaut
477
Rep 10,703
You nailed the issue with PS2s.
And honestly the car is a monster if you let it go, I never understood why people run TC on public roads but thats just me. Save that kind of driving for autox or the track. And just a fun story. The last time I autoxed I finished a run with TC full off came into the paddock and turned of my car. Started up when I was my turn again and went. Only I had forgotten to turn the TC back off. I ran 3 seconds slower than my previous run. I dont know the point of that story, but I like it, so you guys got to read it |
