      07-07-2011, 02:32 PM   #1
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
E92-Lighting | COBB Accessport for BMW N54 MASSIVE GAINS SUPER SALE!!
BMW COBB AccessPORT:
* 2008-2010 BMW 135i
* 2007-2010 BMW 335i/xi/xDrive
* 2008-2010 BMW 535i/xi/xDrive
POWER. FLEXIBILITY. CONTROL. The AccessPORT is the industry leading OEM ECU flashing, managing and monitoring assistant. Unlock power hidden within the ECU by replacing conservative factory settings with more aggressive calibrations. The result is impressive gains in torque and horsepower while maintaining a high degree of safety. The AccessPORT comes with pre-installed maps that are optimized for common performance modifications.
Tuning flexibility ranges from simply loading one of the included performance maps designed for common modifications, all the way to complete custom map authoring using our powerful AccessTUNER software. Extract maximum power from virtually any modification while retaining the driveability and sophistication inherent in the OEM ECU.
AccessPORT Advantages!
* New Alternate Throttle Maps to tune throttle response to your preference
* Incredible power gains are just a few clicks and a flash away.
* Sophisticated logic of the OEM ECU remains intact, providing refined response, excellent driveability and precise control.
* Hand-held flashing lets you control what is stored on the ECU, when-ever and where-ever you want.
* Installs in just minutes through the OBD-II connector. No tools or other actions are necessary. Simply flash and drive.
* Grows with your modifications by changing maps that match your mods.
* Select from Off-The-Shelf maps to match your modifications or take your BMW to a Pro Tuner for professional dyno calibration.
* Uninstalls just as easily and returns ECU to stock configuration.
* Conveniently data log sensor values for up to 10 hours to perform in-depth analysis without the need for bulky laptops or other equipment
* Vibrant-color, user-configurable auxillary gauge. Live Data lets you view real-time data from any of the data channels that can be data logged.
* Performane tools record 0-60mph times and 1/4 mile ET and Trap Speed. See real world impact of modifications and tuning changes.
* Intuitive DTC code reading provides the trouble code and a brief description to help diagnose issues easily. Reset the ECU to clear codes at your convenience.
* 30 Day Satisfaction Guarantee.
2007 Support Info
The same AP-BMW-001 AccessPORT used on 2008-2010 135, 335 and 535 N54 equipped BMW’s will work on 2007 BMW 335i vehicles with a simple firmware update to the latest version. The existing Stage1 calibrations apply to 2007-2010 models. Both manual and automatic vehicles are supported. Be sure to update your AccessPORT to the latest BETA firmware prior to initial installation.
Current AccessPORTs will need to be updated to BETA Firmware to take advantage of this update. To update to the latest BETA firmware version download AccessPORT Manager 2.0, start the program and then select the “Options” menu. Next, select “Check for beta firmware” and then update your AccessPORT. All maps will be automatically updated and loaded onto your AccessPORT.
As with the release of the 2008-2010 BMW AccessPORT, not all ROMs may be supported immediately. If an unknown ROM is encountered, follow the ROM dump procedures and we will add support for your ROM as quickly as possible. Email the ROM along with the year, model and transmission type to rom@cobbtuning.com.
      07-08-2011, 04:31 PM   #2
E92-Lighting
discount codes all sent!
      07-12-2011, 03:12 PM   #3
E92-Lighting
discounts applied on www.e92-lighting.com
      07-14-2011, 05:21 PM   #4
E92-Lighting
      07-18-2011, 03:56 PM   #5
E92-Lighting
      07-20-2011, 03:06 PM   #6
E92-Lighting
      07-22-2011, 03:05 PM   #7
E92-Lighting
      07-25-2011, 04:22 PM   #8
E92-Lighting
      07-27-2011, 03:58 PM   #9
HIPSI
21
Drives: 08 135i
Please PM best price shipped to 77070.... Thx!
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler
22 C8 Corvette 3LT HTC
      08-01-2011, 04:28 PM   #10
E92-Lighting
      08-04-2011, 05:29 PM   #11
E92-Lighting
      08-07-2011, 07:48 PM   #12
E92-Lighting
      08-10-2011, 05:16 PM   #13
E92-Lighting
      08-15-2011, 03:28 PM   #14
E92-Lighting
      08-22-2011, 04:07 AM   #15
EthanM386
8
Drives: 2016 M3
please PM price shipped to 90065. thanks
      08-24-2011, 03:56 PM   #16
E92-Lighting
      08-29-2011, 05:17 PM   #17
E92-Lighting
      09-06-2011, 04:07 PM   #18
E92-Lighting
      09-09-2011, 07:43 PM   #19
E92-Lighting
      09-12-2011, 06:41 PM   #20
E92-Lighting
      09-19-2011, 04:30 PM   #21
E92-Lighting
      09-23-2011, 04:29 PM   #22
E92-Lighting
