06-29-2011, 10:53 PM | #1 |
132
Rep 556
135/N54 Excessive Oil Consumption ?
I just "topped off" my car 5 weeks ago... this is how it read today.
I'm a bit concerned. 21,000 miles, my second BMW with the N54.
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008 |
06-30-2011, 11:30 AM | #2 |
132
Rep 556
WOW
I'm overwhelmed by the responses !
So NONE of you have an opinion or have experienced this ?
06-30-2011, 11:42 AM | #3 |
381
Rep 2,926
Drives: Cayman GT4, 135i
Or people sleep at night :P
Anyways, Assuming when you topped it off it was at MAX, you have a problem. Just to be sure, go to a flat level road and check again. Once I was on a really steep downward hill and my car showed almost 0 oil. I'm pretty sure that's your case, if it isn't then you should take it to the dealer if you can recheck it and it is at the same level.
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
06-30-2011, 11:48 AM | #4 |
Resident Kerbalnaut
477
Rep 10,703
What do you want us to say? You have an issue, get the dealer to fix it.
Modern engines don't eat oil like that after break in. Personally my N54 ate a quart before it's first service and hasn't eaten any oil since That was a scary day, I was taking some fun turns quickly and suddenly the dashboard lit up and the engine cut due to low oil. I turned so tightly that I oil starved the engine It can be any number of things including a misaligned head gasket or a leaky turbo. Under the hood do you see any oil residue? Don't be surprised you have to fight for a work order for a full engine teardown Last edited by BrokenVert; 06-30-2011 at 11:53 AM.. |
07-01-2011, 08:33 AM | #5 |
132
Rep 556
