06-15-2011, 08:30 PM | #1 |
Rep 13
Software Version and Servicing
I'm taking my 135i with Dinan Stage II in for the pre-tensioner recall, oil change and an e-brake issue this weekend. When setting up the appointment, I requested that they do not re-flash the ECU. Is there a way for me to check what software version I am currently running so that I can make sure it isn't tampered with?
The reason I requested this is because the advisor informed me they would need to re-flash with the "new version" Dinan Stage II which is less powerful than the original I am running. I have also been reading on the forum that the new base software version causes a slower throttle response which the advisor confirmed for me. I'd like to keep my existing set up since it's currently precision tuned perfection IMO. I have seen a few posts in the past about accessing a diagnostic menu but no one was able to confirm if the software version is visible or accurate based on what they flash. Thanks in advance for the help! |
