06-13-2011, 09:30 PM | #1 |
292
Rep 1,473
Intake valve cleaning time.
I have the intake manifold off and I am ready to clean but I have a few questions.
1. How do you turn the engine? I assume that one would turn the engine with the crank pulley. Is this the easiest way to open and close the valves? Also, what size is the nut? 2. How do you seperate the metal piece that connects to the intake manifold from the plastic wire case? 3. Should I clean the intake manifold since I have it off? What should I use to clean it? 4. I am going to use Redline SI-1 to soak and clean the valves. I bought a gun cleaning kit that contains brass brushes to brush off the carbon. I heard that Redline SI-1 has the highest concentration of PolyEther Amine which is supposed to be great at breaking down the carbon. Are the other cleaners that might be better? My valves looked pretty dirty but I would say that they are probably average for 28k. Cylinders 1,2 and 3 were cleaner than 4,5 and 6. |
06-13-2011, 09:56 PM | #3 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
Take photos and keep us updated on what happens! I'm certain that I'll be doing this soon.
2008 E82 N54 || Stage 2 -------- Gone to a good home. |
06-13-2011, 10:11 PM | #4 |
292
Rep 1,473
I attempted to take some pics but I had a very difficult time getting any good ones. I have a Canon SLR but for some reason I wasn't able to get enough light in the valve area.
06-14-2011, 01:30 PM | #6 |
519
Rep 1,501
Not trying to bash at all, since I envy your courage to attempt said maintenance...BUT wouldn't you have a complete game plan going into this?
Good luck, miiipilot
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
06-14-2011, 07:28 PM | #7 | |
292
Rep 1,473
Now, I am half way done. I have completed cylinders 1,3 and 5. It is easiest to move the valves by leaving the car in gear and pushing it back and forth. This will allow you to close the valves that you are working on. This is not rocket science but very time consuming. I am sure that it will be worth is when I am done. I am just closing the valves and using puring in Redline SI-1 to to soak the valved. Then I am using a gun cleaning kit and microfiber towels to clean the valves and port. It is actually pretty bad for only 28k. |
06-15-2011, 08:46 AM | #9 |
105
Rep 2,696
Easiest way to open and close the valves is use a breaker bar into the crank and turn it. Usually you can just insert it w/o needing a socket as there's a square hole there just for that. That's a general rule though that I've seen on about 90% of the cars i've worked on. Never looked at ours though. But that's much easier and safer than rocking the car while it's in gear.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
06-16-2011, 06:59 AM | #10 |
292
Rep 1,473
Done.
This is a very nasty dirty job but also not very difficult. If you have any wrench turning skills you can do this. Mostly unbolting and unpluging a lot of things to get to the valves. If you plan on keeping your car past the HPFP warranty you will need to know how to remove the intake manifold because it sits directly below it. Make sure that you remove the plastic shield underneath the car before you get started. It is much easier to turn the engine with a 22mm socket on the crank. Get a good copper and nylon brush set. I used a gun cleaning kit but I wish that I would have had a wider variety of brushes. The valves sit pretty deep and they are very difficult to get to . Get a good pick set. I used a dental pick but I am sure that something better is out there. I used the so lightly scrape the valves. You must have compressed air to blow the junk out. I went thought about 15 microfiber towels. So be prepared and buy a bunch of them before you get started. I used Redline SI-1 fuel injector cleaner and it worked pretty good. The next time, I will let it sit on the valves overnight. |
06-16-2011, 07:53 AM | #11 | |
137
Rep 1,450
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
06-16-2011, 08:14 AM | #12 |
292
Rep 1,473
06-16-2011, 11:45 AM | #13 | |
137
Rep 1,450
Interesting. It must do something as mine does collect oil
06-16-2011, 02:58 PM | #14 |
Indian Stig
29
Rep 1,002
My PCV system isn't doing much as my intake pipes and FMIC are full of oil. I've got the AR design OCC on order and it should be here soon. Some people have issues, some don't... if you notice oil seeping out of your intake pipes then you definitely have some issues!
06-16-2011, 05:59 PM | #15 | |
890
Rep 7,047
There will always be some oil in there. If you notice oil seeping out of your intake plumbing, then you need to tighten up the clamps. If oil is getting out, then so is boosted/pressurized air. At what point in the intake path did you notice oil seeping out? |
06-16-2011, 06:20 PM | #16 | |
European Editor
10589
Rep 22,992
I really do not think anyone knows the answer to this question about an OCC. Time will tell though. My buddy sprayed down the valves(he used Seafoam, some use BG products) on his RS4 over a few days time. You really gotta let the carbon soak up as your cleaning agent - in order to soften the carbon enough to use a pick tool. I know LiquMoly makes an intake tract cleaner... I have used it on my old e36. It comes with a really long tube to get deep into the intake manifold. http://www.amazon.de/Liqui-Moly-5111...=3GW8AGS1IA178 As for the oil in the intake track... I wouldn't worry about that too much. Every turbo engine will have some blowby and some buildup of oil inside the intake pipes/FMIC. As for an OCC... have you seen the ProVent one by Mann. ? Dackel PS: I can not wait to see your photos! |
06-16-2011, 08:38 PM | #17 | |
Indian Stig
29
Rep 1,002
I'll be taking a better look at this in a few days as I've got an HPF FMIC waiting to install and an AR Design OCC. First thing I'll do is check to see how tight the clamps are (or aren't).
06-18-2011, 05:47 AM | #18 | |
292
Rep 1,473
If I was going to pick up an OCC it would be the Provent 200 OCC. I am considering purchasing one but I just don't know enough about them to spend the $150. I have read too many other threads on this board in which their OCC was completely dry after a certain amount of miles. I tried to take some pics but I wasn't able to get enough light to bounce off of the valves. Flash would not do it and the flashlight that I was using was pretty poor. To give you an idea, I probably spent an hour to clean each cylinder. I poured Redilne Si-1 on the valves and let it sit for about 30 minutes to an hour, then I scrubbed away. I good pick set would have made this job much easier. With the right tools you can do it quicker. I was able to get 1,3 and 5 and 2,4 and 6 to close at the same time so this made it a little easier. I really don't want to do this again because it was a PITA but needed. I would say this, if you have more than 30k you probably need to clean your valves. I would not do it if I had to pay someone at 30k but if you have some basic wrench skills it would be worth it. I also resued the intake manifold gaskets. These gaskets looked brand new with 28k on them. |
06-18-2011, 01:05 PM | #19 |
28
Rep 1,938
There will always be oil mist in the pipes. Unless you clean everything out carefully and completely bypass the PCV system at the same time (with a catch can vented to atmosphere or whatever) It did this on my old Talon. I does make a difference as the oil mist that collects in the intercooler hurts it's ability to cool. Over time you can lose performance over it.
06-21-2011, 10:19 AM | #20 |
Rep 145
Drives: 2008 135i Convertible
Is this covered with the 4/50 US warranty? I would think this should be part of the regular maintenance given it is 'normal' buildup on a DI motor. Has anyone had this covered?
06-21-2011, 11:38 AM | #21 |
Indian Stig
29
Rep 1,002
Not directly, I believe cleaning the intake valve or replacing the top end has been covered under warranty only to those that are having some severe issues that can't be fixed by other means. I believe the decision to perform such a service is at the discretion of BMW NA, and not the dealership.
06-29-2011, 12:30 PM | #22 | |
I'm just a cook
24
Rep 971
