      06-11-2011, 08:20 AM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
New Meth "X" Kits with new FSB Integration - GREAT DEALS!!!!
Methanol/Alcohol/Water injection, commonly referred to as "meth", allows you to make tremendous amounts of power on pump gas. The effect is similar to running 104 octane all the time, with additional cooling benefits allowing for more power than you could ever make on race gas alone. The install is challenging, requiring you to drill and tap a location for the nozzle, but the performance benefits greatly outweigh that.
This unique kit locates the methanol pump in the tank for easy install and removal. The tank/pump then can be placed anywhere in the trunk for easy access and removal. All kits are also available with a less expensive traditional 1 gallon universal tank. Those who prefer an engine bay mount setup may also locate the pickup in the OEM washer fluid reservoir.
We've selected the 250psi pump for its superior atomization and flow characteristics relative to less expensive 150psi pumps. This kit also features a high speed solenoid for precise control and a CM10 super atomizing injection nozzle perfectly sized for the 380-440whp range.
This kit integrates with the JB4 tuning system using the included FSB controller which allows for precise methanol solenoid mapping based on boost, throttle position, RPM, air intake temperature, advance, and other data elements available to the JB4 through its CANbus system. In addition the FSB feeds back an independent signal with pump loading and flow information allowing for safe and smooth progressive boost mapping. If the tank runs empty or flow drops for any reason the JB4 will safely back down performance to avoid knock. In addition methanol can be activated or disabled from the drivers seat and displayed in dash using your steering wheel control menu.
For those who prefer a more universal approach we also offer your choice of the VC2 and CMGS integrated progressive controllers. The VC2 is panel mount and tucks away in the trunk or glove box while the CMGS can be mounted in any universal gauge pod. Both feature adjustable progressive spray, boost readings, and configurable display options.
N54 X METH KIT (1GAL. STD. TANK, SOLENOID + FSB) - 429.00
http://www.n54tuning.com/index.php?_...d&productId=84
N54 X METH KIT (1.5G QUICK MOUNT TANK, SOLENOID + FSB) - 479.00
http://www.n54tuning.com/index.php?_...d&productId=85
N54 X METH KIT (2.2G INTEGRATED TANK, SOLENOID + FSB) - 529.00
http://www.n54tuning.com/index.php?_...d&productId=86
      06-23-2011, 10:46 AM   #2
Mike@N54Tuning.com
4918
Bump for some Cool Meth kits for the summer heat!
Mike
      07-02-2011, 08:59 AM   #3
Mike@N54Tuning.com
4918
Bump for some great Meth Kits
In stock and ready to ship at www.n54tuning.com
Mike
      07-03-2011, 10:24 PM   #4
Boosted1
Drives: 135i n54
How long will these prices last?
      07-05-2011, 12:43 PM   #5
Mike@N54Tuning.com
4918
I don't see them changing for the next few months..
Mike
      07-07-2011, 10:54 AM   #6
Mike@N54Tuning.com
4918
Bump for some "cool" meth kits!!
Mike
      07-26-2011, 09:00 AM   #7
Mike@N54Tuning.com
4918
Bump for some great meth kits...
Mike
      07-27-2011, 02:23 PM   #8
calhounboi
Drives: 2008 135i
Bump 2 you sir. Ordering mine today
      04-06-2014, 10:59 AM   #9
jbarzelatto
26
Drives: 2011 135i Lemans
hello.
I am new in the meth bizzz and want to install it in my n55 135i. I am located in Chile, but you would ship it to a friend in STL.
So my question is, I have a local seller, selling a Devilsown tank and solenoid, and sprayer, but I want to integrate it with JB4. So what would i need? is the FSB enough, or the cool mist works too?
let me know please and thank you!
      04-06-2014, 02:52 PM   #10
Mike@N54Tuning.com
4918
Originally Posted by jbarzelatto View Post
hello.
You would need the FSB and solenoid. Its probably best to get the full kit direct from us unless you are getting an unbelievable deal on the other components.
Mike
      04-06-2014, 05:51 PM   #11
jbarzelatto
26
Mike
Thanks for the answer Mike.
Mainly, the reason is because of the shipping and customs I need to pay if I buy the whole kit from you.
The devilsown I tell you about has the tank, the solenoid, the sprayer, and the filter. So why do you say I would need a solenoid from you? Is there a difference? And does the bms kit come with all the lines and hoses?
thanks!
      04-08-2014, 08:30 AM   #12
Mike@N54Tuning.com
4918
thanks!
I am not sure what solenoid that kit comes with and if its compatible with the FSB. The BMS kit comes with all lines, etc. Its a full kit.
Mike
