06-10-2011, 08:29 AM | #1 |
169
Rep 3,831
Coil Spring Spacers.
My KW CS is too low in the rear, its adjusted to its max acceptable height in the rear. Rear tire is tucked under the fender a touch. I want to raise it 0.25"-0.5".
Anyone used coil spring spacers before??? Any issues using them?? NVH?? Thanks.
06-10-2011, 03:41 PM | #4 | |
111
Rep 1,764
aluminium spring spacer, height = 15mm 65030045 aluminium spring spacer, height = 25mm 65030046 |
06-17-2011, 01:00 AM | #5 | |
Supreme Allied Commander
3857
Rep 54,416
Drives: F80 M3
http://www.e90post.com/forums/showth...eight+adjuster |
