06-04-2011, 06:40 AM | #1 |
134
Rep 613
Any way to get oil temp from the OBD port?
I looked at the scangauge II which has just about everything else, but no oil temp.
Anyone know of a plug-in solution or is it going to require an adapter block? thanks |
06-04-2011, 02:38 PM | #3 |
European Editor
10591
Rep 22,992
You can use the BT tool to display/read oil temp.
Also... BMW's Perf digital steering wheel also displays coolant and oil temps. I would bet even generic OBD-II scan tools would show oil temp as well as other data points. Dackel |
06-04-2011, 07:27 PM | #4 |
369
Rep 3,547
The Ultragauge will display oil temperature. Here is a link:
http://www.ultra-gauge.com/ultragauge/index.htm $59.95 Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
06-09-2011, 12:41 AM | #6 | |
38
Rep 701
06-11-2011, 08:23 AM | #7 |
134
Rep 613
They don't list BMW in their gauge estimator list, but it does say it supports CAN-bus which is what I think it'd fall under.
I'll email them and report back what I find. I've since found that leatherZ has a gauge kit and oil distro block which could get us oil temp, oil pressure, and coolant temp. Includes all sensors, instructions, a nice gauge pod that fits in the cubby, gauges and wiring. But, it's about $500. I'm really just looking for something where I can get a baseline for oil temperature in the summer. |
06-11-2011, 03:36 PM | #8 | |
124
Rep 5,627
Tom |
06-19-2011, 07:52 AM | #9 |
134
Rep 613
This isn't looking too promising from what I've found so far.
Ultra gauge didn't get back to me with any answers. Scangauge didn't know if they're planning to add support for BMW. Bavarian Technic's diagnostic tool doesn't yet support 2011 (or I think 2010?) models, but seems like it's the most promising so far. I've asked them what live data can be pulled from the ECU as I've been told that it may not even monitor oil pressure. However the BT tool isn't meant to be an add on gauge, it's a workshop diagnostic tool that hooks up to a laptop. From what I've been able to find out it seems that right now a physical gauge setup is the only real solution. 3d Design makes a really high quality looking gauge pod for the ashtray/cubby (nicer than LeatherZ's IMO) but it's $360 for just the plastic housing. Unfortunately as of now it doesn't look like there's a reasonably priced OBD-II plugin device that can read the BMW specific stuff. |
07-03-2011, 02:10 PM | #10 |
samuray
Rep 139
I do have a question about this. does 128i have a oil temp sensor? anyone know this?
07-03-2011, 03:50 PM | #11 |
134
Rep 613
I've spent some time looking at realoem, and I'm not sure it does. It has what I believe is a coolant temp sensor at the front of the head, right where the coolant pipe attaches.
The only sensor I have found so far on the oil system are the oil level sensor on the sump, and the oil pressure switch on the oil filter housing block. Now I am wondering if the car determines when to give an oil level reading based on the coolant temperature. |
07-04-2011, 04:27 AM | #12 |
samuray
Rep 139
we need a sensor kit to see temp of oil I guess...
05-23-2016, 10:54 PM | #13 | |
Rep 21
oil temp sensor
https://www.bimmerfest.com/forums/at...2&d=1379006123 |
06-29-2016, 05:46 AM | #14 |
458
Rep 590
P3 makes a gauge for our cars and it reads, oil temp, boost, coolant, air intake temp, ignition timing, exhaust gas temp, throttle, speed, 0-60 time.
For the N55 cars in addition to the plug n play of the OBD2, you have to use the analog boost sensor wire. Just had it installed and after a return visit to the dealer everything seems to be working.
2018 MG F80 M3 ZCP | BBS LM?s | Michelin Pilot 4s | BMW HAS Coil Overs | Stek PPF | DINAN CF Intakes | IND Engine cover | Akrapovic Evolution Exhaust |
2018 Champaign Quartz F31 Sports Wagon | BMW 624 wheels | KW Street Coil Overs | DINAN Stage 1 v2.0 | Soul Performance Muffler delete |
06-29-2016, 10:23 AM | #15 |
91
Rep 373
Here's the gauge: http://www.p3cars.com/shop/bmw/bmw-1...p3-vent-gauge/
A little spendy but I like the integration. |
06-29-2016, 03:07 PM | #17 |
20
Rep 79
06-29-2016, 07:33 PM | #18 | |
139
Rep 439
06-29-2016, 07:47 PM | #19 | |
European Editor
10591
Rep 22,992
06-29-2016, 08:34 PM | #20 |
458
Rep 590
Dakelone...you, me and my BMW tech understood the same. N55 uses the boost gauge except in those instances where it requires the additional wire (*it's in the super fine print)
Also...P3 was as useful as a condom after the fact. I sent them 3 emails and they answered none of them...awesome customer support But it's finally working and I'm measuring 15lbs of boost at peak and all other functions work.
06-29-2016, 09:06 PM | #21 |
Слава Украине!
2326
Rep 2,443
The answer is always Carly.
06-30-2016, 02:38 AM | #22 |
20
Rep 79
