05-28-2011, 11:49 PM | #1 |
Some say he bends corners into straights
Rep 41
Signs of HPFP?
Hi guys.
I noticed in the past couple weeks there were maybe 2 or 3 times when the car started, dropped to 400rpm, sputtered, bounced up to 1800rpm and then settled after a bit. I took note, but the car drove fine after. This afternoon I started the car and I immediately got the 'limp' mode engine icon pop up. I let it sit for a minute and it didn't go away so I shut her down (thinking HPFP) and went in the girlfriends car. Later this evening I managed to start the car OK and drove it around, but come Monday I plan to take her in. So is this HPFP for sure? If so, this will be the first one to go. 61k km on the original. It was reprogrammed as per the recall a few months back as well...
Wolfgarde83
2008 BMW 135i | Sedona Red | 6MT | M Sport | Premium Package 1985 Porsche 944 | Alpine White | 5MT |
05-29-2011, 08:10 AM | #2 |
364
Rep 794
About a week ago I had the rpms bounce around and shuddering at cold startup. It's been fine ever since so maybe some bad gas?
I don't know, I just had the HPFP replaced last month (recall - the old one had zero problems). From what I've read the first sign of HPFP failure is long cranks, but that limp mode you have would make me take it in too. |
05-29-2011, 12:01 PM | #3 |
Rep 41
I had a rough idle issue with my 944 a few years back, but that was slightly different... it was idling rough with the rpms bouncing around all the time. That ended up being a vacuum leak and some hoses were replaced.
As for the 1er, I did note some longer crank times back in January or February when it was cold outside, but that seems to have gone away with the warmer weather.
Wolfgarde83
05-29-2011, 12:58 PM | #4 |
76
Rep 676
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
05-29-2011, 10:25 PM | #5 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
As they made alterations for the failing pumps, long cranks are not always the leading symptom. Pretty much anything like you mentioned is the HPFP or the LPFP until proven to be something else IMO. Btw, I think an SES light that comes on while going up hills is a more common symptom than long cranks anyways.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
05-30-2011, 10:38 AM | #6 |
13
Rep 256
I had the same problem when it was around 50º outside but it went away. i was wondering if it was signs of hpfp failure mine was replaced when i got the car from the dealer
05-30-2011, 11:43 AM | #7 |
Rep 41
It seems fine today
The first time the shuddering and bouncing rpms happened was after I didn't drive it for a couple days. If I drive the car more regularly it doesn't seem to happen.
Wolfgarde83
05-31-2011, 09:03 PM | #8 |
9
Rep 70
In the vid that jeremydgreat links us to for the warning signs of HPFP issues, the guy is starting his car with the pushbutton, 'without' the fob pressed into the dash hole???
WTF??? Can someone explain how this works? I tried it today with the fob in the car, but not plugged into the hole...not so much! Thanks! |
05-31-2011, 09:34 PM | #9 | |
G82 Love
464
Rep 422
Drives: 2023 M4 Competition xDrive
MAC
Current: 2023 G82|BG over BLK Prior: 2008 N54 E82|AW over CR Also: FJ60, Volvo Recharge |
06-01-2011, 07:18 AM | #10 |
2452
Rep 7,341
lol.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
06-05-2011, 03:42 PM | #12 |
9
Rep 70
Can someone answer another a$$enine question for me then too??
See`n as I don`t have the Comfort Access...is it ok if I leave the fob in the center console when it`s in the garage? The dealer told me NOT to do that, becuase it would drain the battery over a period of a few days of not driving it. I`m thinking that`s just the standard response, since MOST people DON`T drive stripped down 1èrs? Anyone know for sure? `Cause I do have a bad habit of leaving the keys in my cars when in the garage. ...............and NO, I`m not telling where I live!! |
06-05-2011, 04:33 PM | #13 |
968
Rep 3,323
I had the recall HPFP replaced in January 2011. They also replaced 3 injectors. I ask why only 3? SA said the part numbers on the others are ok.
2 days ago driving home from work... sprutter.... loss of power... engine light. I limped home. This was Friday. My dealer has service hours Saturday mornings. I went to them and explained the issue. The pulled codes and one of the 3 injectors.. that had NOT been replace failed. They replaced the other 3 and all is well. So, the symtoms are not always the pump. The injectors can fail also. I am hoping I am good to go now till 100K. I'm at 40k now. |
06-05-2011, 06:21 PM | #14 |
123
Rep 2,200
my 08 has done those long cranks whenever it's over 90 out and I drive "spirited"
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
06-09-2011, 08:50 PM | #15 |
Rep 41
Went in to the stealer and they replaced the HPFP and 3 injectors. Running great now!
Wolfgarde83
06-14-2011, 08:13 PM | #16 | |
Rep 47
Wow, that is the exact situation that I had today on my way home. My fuel pump was replaced in March and only 3 of the 6 fuel injectors got replaced. Today, while on a hill, i got check engine light and reduced power (barely enough to get moving). Got home, shut down and restarted the car and all was OK. I wonder how long till it happens again. |
06-19-2011, 02:10 PM | #17 |
Rep 68
ok my car is only 3 weeks old with 1k miles and I just startee to notice yesterday that Im getting long cranks and I was taking a left turn at a good speed and I got a cutoff from the engine when I got back on the gas, could this be hpfp?
God created Turbo lag to give V8's a chance.
Gotta love this car. |
