05-24-2011, 10:18 AM | #1 |
652
Rep 1,406
Drives: 2020 SO - M2C
jb4 what map should I use what map do you use?
Hi I just installed my jb4 over the weekend, and currently using map5 w/ 93 octane. I have no other mods. should I continue or use map 5 or use map 1?
What map do you use? with what other mods? |
05-24-2011, 10:33 AM | #2 |
26
Rep 257
I have DCI and 93 octane I always have it on map 1 and switch to map 2 occasionally to have some fun as you can really feel the power difference.
05-24-2011, 12:35 PM | #3 |
247
Rep 1,827
I have never tried map 5. With just the jb4 I only had it on map 1, but I switched to map 2 after I installed my downpipes. I'll probably leave it on that even after I add my fmic. Oh yeah and I use 93 octane.
05-24-2011, 12:55 PM | #4 |
734
Rep 3,274
I usually use Map 5. Since it automatically adjusts, it's probably the best to use..
When I first started I'd be on map 1. I asked Mike@N54 Tuning if he thought map 2 was alright without DP's if you have a catback exhaust and run 93 octane, and he said as long as youre running 93 and have at least a catback system with the stock DP's, it should be fine once in a while. Don't try with 91 though! Map 2 is a bit more aggressive than the max limit it's giving me on Map 5, so I try not to use it too often until I'm out of warranty and I get DP's..
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
05-24-2011, 01:02 PM | #5 |
652
Rep 1,406
thanks for all the info! i think ill rock map 5 until my dp
05-24-2011, 04:10 PM | #6 |
Rep 340
Map 5 is great and seems to adapt well. I tried some E85 with the 93 (1:3 mix) and I hit 15 psi in 3rd gear.
2019 911 GTS
2017 M4 CV 2017 Mini JCW |
05-24-2011, 08:49 PM | #8 | |
734
Rep 3,274
The catback provides more flow and lowers the back-pressure (as do the DP's, but to a greater effect), which frees up more power. However, the intake could be having a similar effect, allowing the turbos to suck up more air more easily, lessening the workload of the turbos, and increasing your power (especially with a tune). This probably also contributes to more safely running at higher psi. At least that's what I'm thinking..
05-25-2011, 09:27 AM | #9 |
26
Rep 257
Yeah i dont think he'd tell me that its safe when its not...it most likely is an octane issue because you need higher octane for more boost...i switch to map 2 occasionally(like last night with a camaro ss) and the car runs amazing.
05-25-2011, 02:51 PM | #12 |
70
Rep 2,197
haha, I love that almost no-one(atleast where I live) knows what these are/what they can do. I've hurt the feelings of many turbo b series/camaros/mustangs in a nearly bone stock car. Can't wait till I get a flash and a fbo setup
05-25-2011, 02:58 PM | #13 |
247
Rep 1,827
Thats the one thing I really do like about this car. It really does not scream attention as my Evo did and I'm really thankful for that. Its nice to go out and not have everything try to race you.
05-25-2011, 03:23 PM | #14 | |
26
Rep 257
EXACTLY! one of the main reasons i sold my evo! i just feel bad for the kid with the camaro because when i had my evo he said oh its a 4 cyl it cant be too fast (this is when he had his trailblazer ss) i ran him when i had full bolt ons in my evo and beat it bad. then when he got his camaro he wanted it again and lost bad again and now this lol. |
05-27-2011, 08:31 PM | #15 |
76
Rep 5,114
so far map 1 and auto tune have felt similar to me, so i'm just going to wait until next week when i get my intercooler and downpipes put on to really experiment with the 3 maps.
I ran map 7 on my old 135 with JB3 a couple of times to see what was what, and it was a nutty map. I thoroughly enjoyed playing with in once in a while. So i can't wait for some supporting mods to see how it goes. |
05-27-2011, 08:58 PM | #16 |
57
Rep 2,251
+1 i do the same. Occasionally map 5, but mostly 1 and 2
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
05-27-2011, 09:51 PM | #17 | |
734
Rep 3,274
Map 5 is also on the conservative side in earlier updates. The more updated you stay, the more aggressive (within safe bounds) it gets. Also, it probably takes a bit of driving, plus at least a few pulls at wide open throttle on map 5 to get the chip to fully gauge what's going on in your engine and adjust accordingly
05-27-2011, 10:24 PM | #18 | |
76
Rep 5,114
I do plan to test it out some more, but i didn't want it to learn rush hour driving style when was the last update? mine should be the april 20 or 22nd one where the exhaust flapper was activated. |
