05-06-2011, 03:06 PM | #1 |
Bashar
418
Rep 1,125
Help ! What I'm I doing wrong here?
Ok so I went to the dragstrip a couple days ago and was somewhat disappointed with my times. My best out of 4 runs was a 13.609 @ 99.9 MPH. I was hoping for a little better times somewhere in the 13.3-13.4 area. My only mods are BMS DCI, muffler delete, and tires (Star Specs 265r/245f). I was also running with 1/2 tank of gas(91oct)
Temp: 90 degrees, low humidity (if any), headwind at about 10mph. Driving technique: Small 1-2 second burnout to clean off the tires and get a little heat in 'em. At the line, I brake-torqued to about 2k rpm then let off the brake and hammer the gas at the 3rd yellow. There was no wheelspin each time I launched. Transmission was put into Manual mode with me doing the shifting at about 6700rpm. So my question is, what went wrong here? or is this normal for these conditions? Timeslip: |
05-06-2011, 03:22 PM | #2 |
107
Rep 2,696
Well you may want to try raising your launch rpm. You're driving in a fairly high temps and you have the DCI which when at the line is very prone to heat soak. Especially after a burnout and reving the motor. You going to lose a lot of power there till you get moving.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
05-06-2011, 06:20 PM | #3 | |
23
Rep 475
That is actually not bad, weren't magazines getting like 13.3 13.4 stock? Fill up with 93 and go there when the temperatures are in the 60s and you will do that much better. |
05-06-2011, 09:15 PM | #4 | |
Bashar
418
Rep 1,125
05-06-2011, 09:18 PM | #5 | |
Bashar
418
Rep 1,125
on a side note; my 60' improved by 0.2 over the stock runflats. both were at the same psi (36). yet, my E.T was exactly the same as when I was stock. Only thing is, the weather was a lot cooler back then. |
05-07-2011, 02:59 PM | #6 |
107
Rep 2,696
That psi for drag racing seems high...try maybe 30-32??
05-07-2011, 08:39 PM | #7 |
Bashar
418
Rep 1,125
05-08-2011, 02:12 AM | #8 |
50
Rep 546
I guess you could try a 2nd gear launch with full powerbrake, but a stock car might bog.
And sorry to say, that DCI on a stock car is costing you some power, I'd ditch it unless you get a tune. With 225/245 star specs, SSTT, and a helene drop-in filter, I ran 12.9@109, to put it into perspective. Unless you're going with a serious tune, that DCI will hurt power because the motor really doesn't need that extra air and the heatsoak is killing you.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
05-08-2011, 08:21 AM | #9 |
23
Rep 215
If you are rasing your rpms at launch and you get wheel spin, you obvisouly could use more traction to take advantage of the resulting additional power. I would also play with lower psi in the tires with no burnout for street tires.
JB4 l Berk AB l AP Mids l PLM DP's l RSD CP l Injen CAI l BSH OCC l ETS FMIC l Koni FSD's l BMW Performance Springs l Complete M3 Frt & Rear l Dinan Shock Mnts & Camber Plates l Quaife LSD l Morel Speakers l Zapco Amps l BMW SS Pedals l Pearlescent Brake Handle l 30% Tint l ICarbon Dry Diffuser l Matte / Gloss Grills l Black 135i emblem l P3 V2 Gauge l SF-71's l Conti DW's 235/265-19's l LCI Tails l Lux H8 |
05-08-2011, 07:25 PM | #10 | |
Bashar
418
Rep 1,125
On one of the runs I accidentally clicked 2nd gear right at the launch. It resulted in a 2.3 60' and a 13.7 at 101mph. I think ill do 2nd gear launches after I'm tuned |
05-12-2011, 02:59 PM | #11 |
12
Rep 150
1/4
I had to test mine out as I have only done a few Autocross events, Launch was Very Tricky!
I managed a couple 2.0X 60' early on. The track was very well prepped and as the day cont on and got warmer my 60's were 2.1-2.2. I seemed to have best luck around 2k rpms, any higher would spin. I managed a 13.512 @ 104.01 mph w/ stock setup. I do have BMS DCI (leftover fr prior 335Xi ) I might install and drag again this Friday. I didn notice when its Hot weather lowend loss on my 335, but high rpm seemed to pull harder. Don't be too hard on yourself, def was a HOT day for your runs ! Good luck!
E92 M3
05-12-2011, 03:30 PM | #12 |
107
Rep 2,696
I agree with this....before you said if you rev'd any higher you were breaking loose, but now you have no wheelspin?? You contradict yourself here. Need to lower psi and raise rpms and you'll launch better
05-13-2011, 01:35 AM | #13 |
Bashar
418
Rep 1,125
I think the wheelspin was also due to not doing a small burnout before the run
05-13-2011, 08:00 AM | #14 |
107
Rep 2,696
On street tires a burnout really doesn't do anything for you...
05-13-2011, 11:49 PM | #15 |
Bashar
418
Rep 1,125
05-14-2011, 12:39 AM | #16 | |
1538
Rep 3,407
The compound in radials are designed to gum up and be sticky once heated-- street tires don't really perform well when heated up. Also, you can't really say that a certain tire likes to be heated up as there are many factors during each run. |
05-14-2011, 10:01 AM | #17 |
107
Rep 2,696
Star specs are designed as an autocross tire. They perform equally when cold or hot. Car and driver did a tire comparison and showed that Not trying to bash ya here or anything so please don't take it wrong here. Just trying to give you as much information as we can to help get those results you want man.
http://www.caranddriver.com/reviews/...r_spec_page_11
05-14-2011, 07:15 PM | #18 | |
Bashar
418
Rep 1,125
