04-18-2011, 05:06 PM | #1 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
>> HP Autosport << Stoptech Big Brake Kit - EXCLUSIVE Pricing for 1Addict Members
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track. Advantages of StopTech over other brake upgrades: -Shorter Stopping Distances -Better Brake Modulation -Firmer Brake Pedal -Less Brake Fade Feature Benefit Summary: -Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel -Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life -The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper -Track testing of new applications ensures optimum performance The key here isn't about the weight savings but the increase in the amount of heat capacity available. Application and Pricing Front 14 inch Sport BBK ST-60 6 Piston Calipers Floating 355x32mm Rotors Stainless Steel Braided Brake Lines Rear 13.6 inch Sport BBK ST-40 4 Piston Calipers Floating 345x28mm Rotors Stainless Steel Braided Brake Lines Please shoot us a PM for your 1Addicts Member price! We are located in Santa Barbara, CA but we ship worldwide and have many satisfied customers around the globe. Please shoot us an email or give us a call and we are more than happy to help you. Last edited by HP Autosport; 04-22-2022 at 01:15 PM.. |
04-19-2011, 04:28 PM | #2 |
153
Rep 2,757
Drives: 2017 Audi A4
Dyou guys sell stoptech pads by themselves? If so, will they fit the oem calipers just fine, etc. Lemme know cuz im not too happy with my CC pads.
04-21-2011, 07:27 PM | #3 |
3847
Rep 54,376
Drives: F80 M3
06-21-2012, 07:34 AM | #4 |
MSgt (ret)
563
Rep 2,116
Drives: VO 1M #739/740
Fit 1M with Apex ARC-8?
I have a 1M and use the OEM wheels for DD but for track I use the 18x10 Apex ARC-8 rims...will this kit fit inside the Apex rims?
If so, please pm front and rear calipers with drilled rotors or can I use the OEM rotors?
06-21-2012, 11:15 AM | #5 | |
3847
Rep 54,376
Drives: F80 M3
1M takes M3 brake applications: http://www.m3post.com/forums/showthread.php?t=513125 |
06-25-2012, 12:30 AM | #8 |
3847
Rep 54,376
Drives: F80 M3
10-12-2012, 05:31 PM | #9 |
3847
Rep 54,376
Drives: F80 M3
Stoptech BBK
You don't have to spend a fortune on a BBK. Shoot us a PM for best prices!
With Stoptech you can buy pads in just about any compound and just about anywhere. |
02-25-2013, 01:23 PM | #10 |
3847
Rep 54,376
Drives: F80 M3
05-14-2014, 12:51 AM | #12 |
3847
Rep 54,376
Drives: F80 M3
