03-24-2011, 09:24 PM | #1 |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
Power ms-8 with oem power wire?
If I'm using the MS-8 only as a processor (using aftermarket amps) can I run it on the oem power wire for the HIFI amp (HIFI amp has been removed)?
Can't be bothered to run another power wire from the battery, I've already run 2x 4 guage cables. Either I use the oem power wire, Or it will have to share a 4 gauge wire with a 2 channel amp (15amp fuse) and a sub amp (25amp) through a splitter. Thoughts? |
04-09-2011, 04:29 PM | #3 |
688
Rep 6,845
For future reference, the MS-8 draws 1amp when you're not using the internal amps
