03-24-2011, 04:16 PM | #1 |
19
Rep 817
Has BMW had different TPM systems?
This is my 2nd BMW with RFTs and a tire pressure monitor system. However, it's the 1st time my non-TPM-sensor-equipped winter tires/wheels cause the TPM system to display "inactive" when I start the car.
I have the feeling that my last BMW ('06 Z4) had a TPM system which did not use sensors in the wheels, but rather it used the stability control system's wheel speed monitor to measure rotational diameter. Is this the case, or am I misinformed? One thing's for sure - I never got any warning lights or gongs from my Z4, and I used the same set of winter wheels. |
03-24-2011, 04:39 PM | #2 |
Moderator
369
Rep 4,745
Absolutely correct.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
03-24-2011, 08:42 PM | #4 | |
8
Rep 247
Drives: '11 128i, '92 325is
It's for your own safety..., as always.
03-25-2011, 09:56 PM | #5 |
Let's save military ranks for those who earn it!
45
Rep 1,161
Drives: ...on the Ragged Edge
US-mandate. They still use the Traction Control / ABS system in other countries...such as up here.
Richard
2013 BMW M3 Individual -- Fire Orange (sold) 2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold) 2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold) 2009 BMW 135i M-Sport Coupe -- Space Grey (sold) |
03-25-2011, 10:49 PM | #6 |
223
Rep 738
The TPM sensor also changed in 2009 or there abouts. So their is an early version and a later version and the two are incompatable with each other.
03-26-2011, 06:10 AM | #7 | |
European Editor
10589
Rep 22,992
There are two TPMS that use TPMS sensors. Sept/2010 builds is when they changed. As stated above... BMW HAD to use this TPMS bc of a mandate from Congress. You can thank Ford and their ExplodeR/Firestone tires for that. So we have a USA TPMS and a ROW one. Canada gets the ROW one. Dackel |
03-26-2011, 09:37 AM | #8 |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
03-26-2011, 09:50 AM | #9 | ||
Resident Kerbalnaut
477
Rep 10,703
I was driving on the highway at ~60-65 in my 00 302 Merc Mountaineer and I had a blowout in the rear. The tire completely stripped itself from the wheel. I controlled the car and brought it to a stop. After I got towed I demanded that the shop examine the rest of my tires. So they pulled them of. All three had sidewall and interior cracks like no tomorrow. They were just a poorly designed tire compound that failed catastrophically. I do think that the amount of rollovers caused by the tire where pure human stupidity and the fact that nobody ever trains the vast majority of people in blowout control, ie don't hit the gas or break just ride it out. |
03-26-2011, 02:28 PM | #10 |
223
Rep 738
They aren't incompatible. When my wheels cracked I needed a temp solution inorder to keep my life going so I borrowed my friends stock wheels and factory tpms. I have an 08 and he has a 10 my car reads his sensors perfectly
Like I said I'm not sure about the year of the change but there are two models of sensors and you have to have the right ones for the system to recognize them. I know because I bought a new set of wheels from tire rack with tires and sensors installed for my 2011 and they installed the "older" sensor and I had to replace them with the newer sensors for the system to work. Maybe our Tire Rack guru can chime in here. |
03-26-2011, 05:03 PM | #11 | |
45
Rep 1,161
Richard
03-26-2011, 05:07 PM | #12 | |
Resident Kerbalnaut
477
Rep 10,703
Regardless I was fine and my dealer payed for the busted wheel and all new tires. I went with BFGs and I still run them on the car now. Never had another issue with blown tires. Although I should say that my Merc has the SVT H/O package, so I never had suspension issues with it. |
03-28-2011, 06:56 AM | #13 | |
66
Rep 1,734
Not saying Firestone is blameless, either - there may have been issues there as well. Last edited by jkp1187; 03-28-2011 at 07:08 AM.. |
