02-19-2011, 06:15 PM | #1 |
Moderator / European Editor
1540
Rep 6,754
BIMMERPOST NEWS Part III: BMW 1M - Nobility At High Speed The third and last part of M-Power's series of technical articles just went live (Part I - Part II). It gives a good insight as to how BMW M tested and tweaked the 1-series M Coupé on the famous Nürburgring. Again, here are our favourite quotes: "The most important step in the compact BMW Series 1 was the decision to adapt the extremely agile chassis of the BMW M3." "One of the key points for chassis development is the northern loop of the Nürburgring, for example the Hatzenbach curve, where a sharp right hand bend follows a hard deceleration. “If the car skitters about here and the wheels are in the air, then the ABS prevents the brake from working. The car simply continues to roll forward,” explains Jürgen Schwenker. The brake zone before the “Aremberg” bend and after the “Schwedenkreuz” is a similar point. “These are points where notice whether or not the distribution of the brake force is right" "Future drivers of the BMW Series 1 M Coupé can look forward to the result. After all the latest member of the M model family is a genuine BMW M for pure driving pleasure. The strongest capital letter in the world does not just stand for Myth, but is also a challenge for the automobile developers that they are happy to accept with all the passion they can muster" Continue after the jump to read the whole article. Nobility at high speed. 20.02.2011 It usually takes a car up to 60 months to reach market maturity from the first strategic idea. The fact that things can move a bit faster has already been demonstrated by BMW M with the BMW M3 GTS. When it came to the new BMW Series 1 M Coupé, work also took place at full tilt. There will only be a comparatively short period of time between the decision to implement the BMW Series M Coupé and the planned market introduction in early 2011. BMW M3: extremely agile chassis. Such a high development temp could only be achieved with the passion and know-how of the M team, which made intelligent use of tried and tested modular components. Both the BMW M3 and the BMW Series 1 have plenty to offer in this regard. The most important step in the compact BMW Series 1 was the decision to adapt the extremely agile chassis of the BMW M3. Aluminium parts of the BMW 1 Series M Coupé's chassis. “Despite the small wheel base on light weight, the basic coordination did not take very long,” remembers BMW M chassis expert Jürgen Schwenker. BMW M' s test center at the Nürburgring. The BMW Series 1 M Coupé was finally brought to life on the Nürburgring’s northern loop. Here too the pace was fast. Hence there were only three development passes for the bearing springs before the spring rate and level were right. “However, in order to balance comfort and sportiness, you need to be clear from the start how the final result is to look,” explains BMW M engineer Jürgen Schwenker. Intensively tested an optimzied... Supplementary spring (yellow) of the BMW 1 Series M Coupé's chassis. As well as stabilisers and dampers, it was also necessary to adjust the supplementary springs by means of the spring force and application points. When it came to the development work on the northern loop of the Nürburgring, a number of different teams were deployed in order to coordinate the various components, such as brakes, tyres, chassis and DSC. Variable M differential lock. In countless comparative outings the various components were tested in different variations until the perfect formula was found. Tests in sector "Hatzenbach" of the Nürburgring Nordschleife (image: BMW M3 GTS). One of the key points for chassis development is the northern loop of the Nürburgring, for example the Hatzenbach curve, where a sharp right hand bend follows a hard deceleration. “If the car skitters about here and the wheels are in the air, then the ABS prevents the brake from working. The car simply continues to roll forward,” explains Jürgen Schwenker. The brake zone before the “Aremberg” bend and after the “Schwedenkreuz” is a similar point. “These are points where notice whether or not the distribution of the brake force is right.” Future drivers of the BMW Series 1 M Coupé can look forward to the result. After all the latest member of the M model family is a genuine BMW M for pure driving pleasure. The strongest capital letter in the world does not just stand for Myth, but is also a challenge for the automobile developers that they are happy to accept with all the passion they can muster. |
02-19-2011, 07:20 PM | #5 |
103
Rep 1,417
I didn't know about this prior?
Supplementary spring (yellow) of the BMW 1 Series M Coupé's chassis. (See top of rear shock)
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
02-19-2011, 07:34 PM | #6 |
European Editor
10589
Rep 22,992
02-19-2011, 07:49 PM | #7 |
292
Rep 2,898
02-19-2011, 07:53 PM | #8 | |
European Editor
10589
Rep 22,992
Well... to be fair to the Germans... they do call that part a spring(in the German language). Sometimes they call it a helper or aux spring. We Americans call it a bump stop. |
02-19-2011, 08:15 PM | #9 |
1M advocate
214
Rep 878
It really acts as a spring though BMW designs it to act as a performing component of the suspension instead of just a safety component to protect the dampers.
2012 BMW S1000RR
2011 BMW M3 |
02-19-2011, 08:54 PM | #10 | |
292
Rep 2,898
All hail the noble -- but humble -- bumpstop! Neil |
02-20-2011, 02:34 AM | #11 |
156
Rep 475
Drives: 1///M Coupe & ///M2 CS DKG
thanks
we wainting to a real 1M from Leipzig with his serial parts
- Série 1 ///M BSM - |
02-20-2011, 03:23 AM | #12 |
177
Rep 2,355
Come on BMW stop with the marketing. We know this car was born out of the M parts bin. just annoying how you overcharge for a car that is no greater than the E46 M3. heck the exhaust note sounds like an e46 ZHP. not what I like to see after years of your "research".
Research? How about researching what colors people ACTUALLY LIKE. and stop the halloween nonsense with this orange black and white. Where is your M colors? authentic M colors (at least a variation of blue). Or are you planning on this 1M to be easily refreshed with things it should have came with from the beginning? Pure M? where is the digital temperature in the rev counter like in the e46 M's Great. 60 months is what it took for development of the e46 M3 AND the N54 (plagued with problems) I can only imagine what will occur with the 1M when you give yourself even less time! "It usually takes a car up to 60 months to reach market maturity from the first strategic idea. The fact that things can move a bit faster has already been demonstrated by BMW M with the BMW M3 GTS. When it came to the new BMW Series 1 M Coupé, work also took place at full tilt. There will only be a comparatively short period of time between the decision to implement the BMW Series M Coupé and the planned market introduction in early 2011." EDIT: Ok, Ill admit I woke up that morning cranky and some of what I said sounds borderline stupid. Some days I love the car some days I dont. BUT for example the seats have the same bolstering as my sport package 325i. -_-
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting Last edited by Driv3r; 02-21-2011 at 01:12 AM.. |
02-20-2011, 04:01 AM | #13 | |
Rep 92
That's why the 1M has a faster 0-60 and 60-0 than the e46 M3 right? Or are you classifying "greatness" of a car based on availability of a sunroof and options for exterior color, interior color, and interior trim? |
02-20-2011, 04:48 AM | #14 | |
51
Rep 337
02-20-2011, 05:25 AM | #15 | |
1952
Rep 1,511
02-20-2011, 05:28 AM | #16 | |
132
Rep 1,898
02-20-2011, 05:40 AM | #17 |
51
Rep 337
I could have done without the word "Nobility" in the title. It's an attention grabber alright, but they fail to make a connection in the article, unless it's nothing more than the implication that 1M shares its suspension parts with the "Noble" family of M3's. If anything, the word "mobility" would have worked (slightly) better, given the content and context.
02-20-2011, 06:28 AM | #19 | |
22
Rep 908
(Sorry guys, I had to say it, "It's a moral imperative.")
Vorsprung durch Gas Geben!! 172 of 740 |
02-20-2011, 08:00 AM | #20 |
504
Rep 3,446
Looks pretty good to me. To much complaining.
See my photography at http://ronscubadiver.wordpress.com
02-20-2011, 08:26 AM | #21 |
22
Rep 908
No kidding, take all of the marketing/brand image crap (i.e. ///M car or not) and just look at the car itself and this thing is gonna kick some @ss
02-20-2011, 08:46 AM | #22 |
Rep 111
I just love to hear the opinions of all the armchair experts out there and of course we are all entitled to an opinion. But remember opinions are just that...opinions. Only the passing of of time will decide whose opinions turn out to be fact. I'm gonna put my money on the automotive and mechanical engineers at BMW...they do have a little bit of a track record in regard to producing pretty good motor cars. To show my faith I am paying US$110,000 for my 1M in Australia and happy to do so....stop whinging guys.
