02-06-2011, 09:16 AM | #1 |
294
Rep 1,473
Battery charger for reflash
Is anyone using a battery when they reflash using their AccessPORT? I have not, but I am concerned about the battery dying during the process. If so, what brand/type are you using?
Also, is there a way to turn off the angel eyes. When you power cycle the car my angel eyes come on and they will not turn off with the switch. |
02-06-2011, 09:45 AM | #2 |
23
Rep 358
Drives: White 135i
I didnt purchase the AP for my 1 yet, but I had it on my EvoX and I was having problems with the maps and had to contact cobb to fix the problem and during all of that time my battery didnt die. they tell u to be cautious, but you should be fine imo
02-09-2011, 09:55 PM | #4 |
67
Rep 921
had mine in and out. our cars are new enough that the batteries should be solid enough. Now say in a few years as the battery is getting to the end of it's life it's probably worth it. I did have the problem in the past with a shark injector where it wouldn't update my 6 year old car on it's original battery, put charger on and no problems.
18 X6M, 22 Tesla MYP, 21 Plaid, 19 Ram
02-11-2011, 10:45 AM | #5 | |
40
Rep 1,058
No charger needed
The faster you go, the better it feels
02-19-2011, 02:23 PM | #6 |
294
Rep 1,473
02-19-2011, 03:20 PM | #7 | |
34
Rep 604
use the rocker again to scroll through the different things you can set, until you come to the option that has an icon that looks like a sun...end button to select it, scroll down to off, select again...done and done its all in the manual, page 75 i think...I just had to reset everything after the hpfp reflash. |
02-23-2011, 04:05 AM | #8 |
223
Rep 1,565
An inexpensive battery charger will give you an added layer of protection and a whole lot of comfort. They are under $50 at your local autoparts store.
With the gigantic 50lb BMW battery you should be okay but I would use a charger anyhow. |
