01-27-2011, 08:48 PM | #1 |
51
Rep 337
Interesting Dyno Chart
Saw this in the Z4 forum.. someone dynoed his 35is and here's the result:
http://e89.zpost.com/forums/showthread.php?t=433243 Definitely has me thinking that the 1M coupe dyno that was published recently is conservative. |
01-28-2011, 07:02 AM | #5 | |
292
Rep 2,898
BTW, I'll be seeing my first 1M "in the flesh" later today at the Washington, DC auto show! Neil |
01-28-2011, 07:36 AM | #7 |
11
Rep 350
Very interesting!
Keep in mind that this chart should be influenced by overboost, which will end up in a peak inevitably (at least I think it does?). If I understand the chart right, the engine produces a short time of 370hp (overboost?) which then falls down again but levels more or less at 340hp until 6'250 rpm and then drops finally to 320 at 6'500 rpm and 300hp at 7'000 rpm. Yes, other turbo charged engines handle that better, but it just means that you should shift at 6'500 rpm and that's similar to other turbo engines again. |
01-28-2011, 07:42 AM | #8 |
51
Rep 337
He was going to get a 2nd dyno to compare results... Hopefully soon.
Some ppl have lamented the drop off at higher RPM but you know, when you're going from 371 @4,900 to 300 @7000, it's a stretch to say that the power is falling off a cliff. |
01-28-2011, 08:00 AM | #9 |
31
Rep 515
I know the guy from the Z4 3.5is.
This dyno is done by a wellknown "chiptuner" in Belgium and must be pretty representative. My M3 3.2 did 308 HP over there and by another wellknown 303 HP. I think the 371 hp will be 363-365 hp in real; which is fine also! If the 1M can combine this figures with a better throttle response and a bit less power drop off it will be stunning to drive!!! |
01-28-2011, 08:27 AM | #10 | |
11
Rep 350
The throttle response will only be tweaked, meaning that you will give less throttle and the electronics will give more. I also don't think that they can modify the power drop off electronically. In my understanding (may be wrong) is that the basic characteristic of that specific engine which will not be modified physically by BMW M, as we know today. |
01-28-2011, 08:48 AM | #11 |
7908
Rep 11,785
I am curious to hear what YOU think Neil. If you don't post a thread, send me a PM.
01-28-2011, 08:50 AM | #12 |
68
Rep 883
Couldn't the M folks just adjust the wastegate to hold more boost towards the red-line? There should be enough overhead with these turbos to allow that.
01-28-2011, 02:48 PM | #13 |
103
Rep 2,626
Interesting. Looks like ~340rwp other than that spike.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
