New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      01-27-2011, 11:00 AM   #1
taYab
taYab's Avatar
30
Drives: '06 E60 '09 E89 '14 F25
Rear Brake Lamp Malfuction Sign
Rear Brake Lamp Malfuction is sometimes turned on.
From what I have researched, it's mostly due to aftermarket wheels.
Many E9x guys are seeing this sign as well and they went to stealership and response was just deleting the sign.
Anybody experienced this with aftermarket wheels?
2006 E60 Gone!
2009 E89 Gone!
2014 F25 !!
      01-27-2011, 12:12 PM   #2
HerrK
HerrK's Avatar
42
Drives: 21 X5 40i, 77 R100Rs
Maybe the E9x'er guys new wheels weren't round, causing excessive vibration, and failing the bulbs. Seriously there is no reason aftermarket wheels will affect the rear brake bulbs. The computer is merely sensing voltage/current/resistance @ the bulb. If the bulb is burned out or a poor connection it will cause the Brake Lamp warning to illuminate. Take it to the dealer and have them check the electrical connections.
HerrK - 2021 X5 40i M Sport l PCD l Atlantis Blue/Ext'd Tartufo Merino l M Sport w/blue Calipers l Matt Popular l HK Sound l 740's l Exec & Drive Pro Pack
Sold w/Great Memories - E89 Z4 l ED 2010 l 2011 35i l Crimson/Ext'd Coral Red w/Alum l 6 sp MT l Prem Sound l Sport Pack l 296's
      03-07-2013, 11:01 AM   #3
jpwolfe31
Drives: 2009 Z4 35i
Having the same problem but it is intermittent. I think I have a brake light bulb with a loose connection between the socket and the bulb.
I have taken the covers off in the trunk and am faced with a a couple of white plugs with wires running to them. I assume these are the bulb holders and just pull out as stated in the manual.
Are there any tricks to this? How much pressure is required? Is it just a pull straight back with no twisting? Just being extra cautious as I do not want to break anything.
      03-07-2013, 12:33 PM   #4
ManiacGT
ManiacGT's Avatar
United Kingdom
85
Drives: Z4 sDrive 35i
How can wheels impact on brake lights!? Coincidence if anything. More likely faulty wiring or water ingress in lights.
      03-08-2013, 01:44 PM   #5
raven333
raven333's Avatar
7
Drives: Sapphire Black 3.0siM sport
The lights are LED's not like ordinary bulbs and more resilient to vibration. What you may not be aware is that the E89 has a very high failure rate on the rear light clusters, I had mine changed, why do you see so many on Ebay from a nearly new model???????
zpost
