01-25-2011, 01:11 PM | #1 |
Rep 202
20mm Lowered = 1/2in increase in overall height
Someone want to explain that one for Me?
I can just about understand some increase in overall height because the rear tires are larger in diameter than stock 1 series (but not by 40mm) Still lower than an M3 |
01-25-2011, 10:29 PM | #5 |
AutoXer
34
Rep 683
Not just the rear tires, both are larger. The fronts are 1" bigger diameter, and the rears are 1.5" bigger diameter, which is only a few mm less than 40.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
01-26-2011, 02:01 AM | #6 |
Rep 202
Agreed:
Stock 135i Front 215/40R18 629mm Diameter, 314.5mm floor to axle Rear 245/35R18 629mm Diameter, 314.5 floor to axle 1M Coupe Front 245/35R19 654mm Diameter, 327mm floor to axle Rear 265/35R19 668mm Diameter, 334mm floor to axle So (based on the tyres alone) the 1M is 1/2in higher at the front and 3/4in higher at the rear. BUT - I've seen a number of writeups from reviewers where they mention that the 1M has been lowered by 20mm compared to the Stock 135i. Is the talk of the 1M being 20mm lower just bull or are they perhaps refering to having to cut down the height of the M3 suspension to get it to fit under the 1er chassis? If that's the case, I wonder if it has compromised the handling. Call me old fashioned but, if I hear that a car has been lowered, then I normally expect it to be sitting closer to the floor than before - not higher! |
01-26-2011, 06:05 AM | #7 | |
12
Rep 734
LOL - why would you think "lower" meant closer to the ground? You're talking to a salesman - for it to make sense, stand on your head and re-listen!
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream. - Jeremy Clarkson, discussing the S65 and then S55 M3 engines. |
01-26-2011, 08:00 AM | #8 |
Rep 155
I wouldnt get caught up on the ride height. Look at a 335 coupe next to an M3 coupe. The M3 coupe is higher as well.
[SIGPIC][/SIGPIC] 135i -- Alpine White -- Coral Red -- ZSP Previous --2004 VW R32-- |
01-26-2011, 08:48 AM | #9 |
SMSgt
11
Rep 239
Drives: AW 1M Coupe
There are a few of ways to look at lowered.
1. Are the wheel wells closer to the tires. In the case of the 1M, I believe they are. 2. Is the roof higher from the ground. I believe the roof is the same height or close to it. 3. Is the center of gravity lowered? Not sure on this one, I'll let the experts chime in. The axle line of the car is .5 to .75 inches higher due to the taller tires, but the roof is still close to the same height so the car is lowered relative to the axles. |
01-26-2011, 02:29 PM | #11 |
275
Rep 3,164
Drives: Many
Garage List 2020 BMW M2 CS [0.00]
1994 Audi RS2 Avant [0.00] 2021 Audi RS6 Avant [0.00] 1988 BMW E30 M3 [0.00] 2011 BMW 1///M [0.00] 2017 BMW F80 M3 30 ... [0.00] 2018 Porsche 991.2 GT3 [0.00] 2015 Porsche Macan ... [0.00] 1998 Porsche 993 C4S [0.00] 1994 Lancia Delta I ... [0.00] 2008 Audi RS4 [0.00] |
According to the US brochure I just got, overall vehicle height of 1///M is 55.9 inches vs. 55.4 for the 135i, hence the net increase of 0.5 inches
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock 2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB 1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust 2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods |
01-26-2011, 02:37 PM | #12 |
11
Rep 350
Or is the 1M 20mm lowered compared to the original suspension from the M3? Because either the "20mm lowered" statement is just wrong or we're comparing the false cars here (135i vs. 1M).
