XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      01-12-2011, 08:48 AM   #1
Ian Robb
Drives: BMW X1 xDrive 23d
Question Fuse/wiring diagrams
Does anyone have any idea how I can get hold of a wiring diagram and fuse diagram for the X1 x23d? The fuse diagram provided relies on symbols and some of them aren't obvious!
I am trying to fit a Road Angel device which I would like to hard-wire onto the dashboard. I would like to pick up a live and neutral feed from somewhere. I would like to use the cigarette lighter socket. Could anyone please tell me how I can get to the rear of the cigarette lighter, and also how I can take off the cowling on top of the speedo and rev counter assembly. There are 2 screws in this which I have removed but I would have to use considerable force to remove the cowling top.
Is there anywhere I can purchase a DVD of the instruction manual?
Thank you very much, any help will be greatly appreciated.
      06-07-2011, 07:35 AM   #2
Fliegenfranz
Fliegenfranz's Avatar
Germany
Drives: X1 x20dA
what instruction manual you´re looking for?
      06-07-2011, 09:41 PM   #3
brettnosse
Drives: Mini
I am planning on fitting a UHF Radio to mine, and am going to use the cig lighter cables. that should be fairly accessable.
      06-07-2011, 10:36 PM   #4
AusX1
11
Drives: X1 2.0D Sport
try the I-Drive DIY thread to give you a better idea on the deconstruction you might need to do of the dash
      05-03-2012, 05:05 AM   #5
Bushellj
X1 Owner
United Kingdom
12
Drives: BMW X1 sDrive 18d SE
Access to the cig lighter is quite simple - Just see my instructions for installing a TomTom Sat Nav in this section of the Forum as you have to remove the upper part of the Central Console which is quite easy.
xbimmers
