BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
      01-11-2011, 06:07 PM   #1
ctown113
43
Drives: 2009 M3
2009 M3 Coupe  [0.00]
Installing grills-can i do it myself?
hi guys, i'm about to order blacked out grills for my 2009 e92 m3... and i was just wondering if it's simple enough for anyone to do? i'm no mechanic by any means... or should i ask a professional to do it? thanks~
      01-11-2011, 06:13 PM   #2
pittsy
pittsy's Avatar
Drives: Jerez...E92 M3
It's very easy! Just search on here and follow the steps.
http://www.m3post.com/forums/showthread.php?t=191198
There are other links on that page as well.
08 E92 M3 Jerez Black | Bamboo | 6MT | 18s | 5% tint | No iDrive | Heated Seats | V1 hardwire | ///M Alu Pedals | Matte Black Grills | Painted Reflectors | CF Roundels | GP Thunder 8500k | Remus Race Exhaust | VMR V701 18s Matte Black
      01-11-2011, 06:20 PM   #3
ctown113
43
Drives: 2009 M3
thank you very MUCH!
      01-12-2011, 08:11 AM   #4
BimmerM
BimmerM's Avatar
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
2013 BMW X5 M  [0.00]
2011 BMW M3  [0.00]
It's really easy to do. I suggest using a body panel tool to pop out the grill if you have one. If not then hopefully you have strong skinny fingers.
I create a DIY on this if you are interested in my method. There's plenty of other DIY's out there if mine doesn't suit you. Good luck.
My DIY: http://www.fastm.com/e92m3/editionfrontgrills.html
      01-12-2011, 09:18 AM   #5
Stormtroooper
The General
Stormtroooper's Avatar
34
Drives: 2018 M3CS
2011.5 M3  [10.00]
DIY is very helpful, also very easy. GL
E92 M3
2011.5 AW / DCT / ZCV / ZP2 / Heated Seats (SOLD)
2018 M3CS
      01-12-2011, 10:20 AM   #6
jonasaurus
jonasaurus's Avatar
United Kingdom
76
Drives: E90 M3 [Sold]
+1
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
      01-12-2011, 10:37 AM   #7
ctown113
43
Drives: 2009 M3
THANK YOU! This was very helpful...
Last question, does it really matter what type of black grills I buy and install? I see some for around $40 on eBay, som for $50, and some for $60?
Thanks AGAIN!
      01-12-2011, 11:31 AM   #8
48Laws
705
Drives: '15 F80, '18 991.2 GTS
Anyone who says it's easy is lying. You have to be careful. There's a bend by both headlights. You can easily crack that!
      01-12-2011, 11:38 AM   #9
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
Not if you use the right tools.
It should definitely not be forced out.
      01-12-2011, 11:48 AM   #10
ctown113
43
Drives: 2009 M3
thanks for the heads up... i guess i'll take it to friend who will probably do it better than i could.. he's a mechanic and he never charges for small things
      01-12-2011, 11:49 AM   #11
48Laws
705
What, BMW certified tools or a flathead? Lol
      01-12-2011, 11:56 AM   #12
48Laws
705
Ok! I'm eating crow. Yummy. It is easy. Thought my hands were too big to squeeze behind grill. See, I can humble myself.
      01-12-2011, 12:10 PM   #13
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
LOL. A small flathead will do. I used a body panel tool where one end is straight for the top latches and the other end is angled for the outer latch closest to the headlights.
The latch will pop right out with little force if you press in the little tab on the latch with the tool. If you use your fingers, you will not have enough pressure to press the little tab in.
      01-12-2011, 12:13 PM   #14
jonasaurus
jonasaurus's Avatar
United Kingdom
76
I found using a long flat head screwdriver to poke each the tab one by one while lightly pulling on the grill did the trick. Once you have say the top 2 tabs released it gets easier, the bottom tabs can be done last.
      01-12-2011, 12:22 PM   #15
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
Exactly.
      01-12-2011, 12:24 PM   #16
48Laws
705
Frightening at first, but as everyone has said, very easy. Cracking the bumper on a $70K car is not cool.
      01-12-2011, 12:35 PM   #17
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
Woah, lets hope no one does that.
      01-12-2011, 02:36 PM   #18
M3 6MT
Get to the chopppper!
10
Drives: 2011.5 E93
Getting one of those precision 90 degree tool helped me with the clips near the headlights
      01-12-2011, 02:57 PM   #19
BimmerM
BimmerM's Avatar
2011 BMW M3  [0.00]
I have the 11 pc SIR TOOLS set (got it from Amazon). Has helped me with various installs.
      01-12-2011, 03:05 PM   #20
48Laws
705
Tape a penny to your index finder. That might help with that difficult clip.
      03-05-2011, 12:03 PM   #21
B R A N D X®
B R A N D X®'s Avatar
22
Drives: Fast Cars!
I just swapped out the grilles on my M3 and have a slightly different take on the previously posted DIY info.
Taking the advice I had read here I tried unclipping the clip closest to the headlight first, but it wouldn't budge. After 10 minutes the only thing I had to show for my efforts was pretty sore fingers.
What worked for me was unclipping the bottom clips first, on my car they were definitely the ones that offered the least resistance, then the side clip closest to the center. Once I had every clip unseated except the one closest to the headlight I was able to push that clip in while giving the grille insert a good, steady pressure pull and out she popped.
Also helpful is to use a chair to sit in so that you can use your knee to push the bumper cover back towards the car so it doesn't flex while you pull on the grille thus negating some/most of your force. Once you've removed those 4 Hex screws the bumper cover will work against your efforts as it flexes outward along with the grille piece that you're pulling on. ;-)
-Stu-
2011 E90 ///M3 DCT ZCP | Space Gray | Silver Novillo |
2011 F10 550i | Space Gray | Oyster & Black Nappa | ///M Sport | 8 Spd Auto
"A toast then: To the BMW M3, the greatest all-around car in the world."
-Arthur St. Antoine, Motor Trend Magazine's Editor at Large
      03-07-2011, 03:15 AM   #22
tlr
tlr's Avatar
Drives: 2011 M3 E93
Taking apart the vents, in particular the rounded end piece with the two tabs, is the hardest part for me. I've nearly destroyed mine trying to get that thing apart.
m3post
