01-08-2011, 05:58 PM | #1 |
60
Rep 1,036
Just installed a double sided Vorsteiner bootlid on my E92 today. The one I installed weighed (with paint on exterior and cleacoat interior) considerably more than the advertised weight of 11lbs. I weighed both the oem lid and the Vorsteiner on the same home scale. Vorsteiner is 10lbs lighter (26lbs vs. 16lbs) than OEM.
OEM = 26lbs Vorsteiner double sided = 16lbs Both were weighed as base lid with no emblems, trim, lights, latch, etc or other required parts. |
01-08-2011, 06:59 PM | #2 | |
19
Rep 561
Interesting, thanks. I was gonna do the one-sided trunk from them but was hoping for/expecting more of a weight savings than that....hmmmm. |
01-11-2011, 04:57 PM | #5 |
60
Rep 1,036
No, once you get the trim off the inside, everything is accessible to remove. Took me about 90 minutes to remove and reinstall everything. It is a tight fit, but I was able to transfer all the lights, trim, parts etc from the oem lid. Alignment is a bit tricky, but nothing is too hard.
