01-08-2011, 01:37 PM | #1 |
64
Rep 483
Fixed: Manual mode ignores me.
Fixed: Read below for details.
I searched around the forum and found a few threads on the SMG, but I have the ZF auto. When I'm in D I can use the paddles/gear to downshift from 6 to 5, pass, and then upshift to 6. After a few seconds of the car returns to D on it's own. When I'm in DS mode it and leave it there it shifts more aggressively, like it should, holding gears and more willing to downshifting (the speedof the gear changes aren't faster, but it seems more willing to downshift). My complaint about M mode: When I'm in DS working the gear shift or paddles shifts me to M mode. I'm positive I'm in M mode since I see the M and the gear number I'm in (M6, M5, etc), but for the most part my upshifts and downshifts "requests" are ignored. Unless I'm driving with a heavy foot the gears will stick to redline, but then my upshift commands are ignored until I let off the throttle and the brain upshifts for me. Is the BMW transmission brain just stubborn and M mode sucks or do I have something wrong? When in M mode I want complete and utter control. The paddle switch and gear shift switches work (I guess some people had a bad gear lever switch that didn't register "DS"). In my old Jeep SRT8 the transmission would NEVER upshift for you, no matter how hard you were accelerating. If you let off the gas you'd continue to rev high RPMs as the engine winds down (no nanny to upshift for you). The transmission WOULD downshift as you came to a stop, but that's to keep you from stalling. Full auto worked like full auto. I wish my Z4 behaved the same way in M mode so I could downshift to say 4th, and hold that gear. I just did the 15sec reset on throttle calibration but it didn't help the function of M mode. Please help! Last edited by santov; 01-18-2011 at 09:10 PM.. |
01-08-2011, 09:24 PM | #2 |
7
Rep 114
I have a 2003 with sport and automatic trans and when I am in steptronic mode it will only upshift once I get into the redline(6500K+). As long as I stay out of that it will hold the gear until I change it.
Not sure what you are refering to with DS mode. For me it is either D, which is normal economy early shift daily driving mode. Or pull the shifter left and it is in SD mode which is just like when you push the sport button. The shifts will come later than in regular D mode. Then if I bump it wither up or down it moves to Manual mode M1,M2,etc. In M mode it will not shift up as long as I am not redlining it. It will only shift down as I slow to a stop but then it will only go down to M2. If I want first gear I have to do theat on my own. |
01-10-2011, 01:07 PM | #3 |
Accountant, 1st Class
8
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
Yeah, if you pull your shifter left, towards your thigh, it should stay in manual mode and not shift for you.
Not sure what it does over the redline. It may protect itself, but not sure. |
01-11-2011, 06:31 AM | #4 |
NewFinishColumbia/detailer
604
Rep 2,096
Another thing too is that the steering wheel paddles seem to shift faster than using the gear level. There's a little delay.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
01-11-2011, 02:26 PM | #5 |
64
Rep 483
I'm going to take my car in for service and see if this is a ECU thing. I don't want to rev to redline, but I would like to hold a gear with out the brain upshifting for me.
01-15-2011, 02:44 AM | #6 |
64
Rep 483
Well I took it in for service and after having the car for the day they determined the electric fan was NOT working. According to the dealer when the fan isn't responding the "limp" mode prevents manual control of the tranny.
Smart they build that limp mode in, stupid they don't have warning lights or log it in the diagnostic computer. Supposedly the service tech had to send diag info to BMW who deduced it was the fan. No thanks to any error codes. That's scary that my fan wasn't working. Luckily the temp has been just fine and the weather has been cold. Supposedly I'll get the car back tomorrow and get to check it out. |
01-15-2011, 01:59 PM | #7 |
604
Rep 2,096
Glad you got it figured out for the most part anyway. Waiting to see what the outcome is.
01-15-2011, 04:50 PM | #8 |
64
Rep 483
Just got an interesting call fom my service advisor- Replacing the main electric fan didn't help at all. The only thng they could tell me was the tech is sending "program data" to BMW tech support. Then he told me they needed to order a "special" 60A fuse that won't be here until Tuesday. If I really did have a 60A fuse out I think more than Manual mode on the transmission would be malfunctioning.
I'm afraid they're grasping at straws now and randomly throw parts at the car until something works. I'm okay with it since it's under warranty. Honestly if it was me I'd be replacing the main ECU or transmission controller instead of messing with fuses and fans. Now that I think about it I wonder if it's a bad body ground somewhere. I read another thread that a constant airbag light was really a bad connection on the negative battery terminal. I'll keep you guys posted. |
01-16-2011, 01:04 AM | #9 |
604
Rep 2,096
Please do so if I should have these problems that you are having then I know where to start talking with the Service Advisor. I should be taking mine in to get the oil changed here in a couple of months and I'm going to see if they can get me the new software because the lag in D from a start is annoying at best.
01-18-2011, 10:51 PM | #10 | |
64
Rep 483
Fixed!
Well after having my car for 5 days (partially because of Sunday plus a holiday) I got my car back today.
The service advisor was out to lunch, but luckily the tech made good notes: Quote:
Now sport mode feels awesome and if I flick to SD then work the paddles the tranny shifts pretty quick and holds the gears. I don't rev to redline, but I do like to hold 4th gear when I'm merging, or hold 6th gear for a swift freeway pass. They also replaced my wiper blades for me. I'm happy!! The inside of the car was a mess with dirt and dust everywhere, even black fingerprints on the lower dash. I don't mind cleaning, but I'm a little disappointed they weren't more careful. That's dealerships for you. |
01-22-2011, 03:21 PM | #11 |
57
Rep 822
Kudo's, thank you for posting the cure for your issue. It helps all of us to save time,
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
