12-17-2010, 08:52 AM | #1 |
18
Rep 74
Climate control not working after jump start
Hello, I must have left something on in my car last night and the battery was dead this morning. I had it jumped, and everything is all right, except for my climate control. It lights up, but will not blow air of any temp. Also the air conditioning and rear defroster buttons are not working. Any ideas?
Thank you. |
12-17-2010, 09:41 AM | #3 |
18
Rep 74
12-17-2010, 10:10 AM | #5 |
180
Rep 659
Drives: '22 M5CS, '00 M5, '06 Z4M
Garage List 2022 M5CS [0.00]
2001 BMW 740i [0.00] 2006 BMW M Roadster [0.00] 2012 BMW X6 3.5i [0.00] 2006 BMW 325xi [0.00] 2017 BMW 540xi [0.00] 2000 BMW M5 [0.00] 2001 BMW X5 4.4i [0.00] |
Let's hope so, that climate control module is $500 from the dealer if I remember correctly
If you guys end up need a new module, let me know, I have one in mint condition out of my '05. Chris
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
12-17-2010, 11:00 AM | #7 |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
Is there a fuse to check?
12-17-2010, 11:02 AM | #8 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
It may be a fuse, check behind the clove box.
12-17-2010, 11:08 AM | #10 |
Engineer
216
Rep 2,122
Also it could be your battery reading less then 12.65v very common thing that gives all kind troubles. Solution: Remove battery complete out of the car and charge it to 13.5 -13.75 range, no more then that, let the battery sit out of the car for at list 6-8 hours after it's charged then reinstall the battery (+) first (-)neutral last
12-17-2010, 11:12 AM | #11 |
Engineer
216
Rep 2,122
It happened to me and freaked me out, Also before you put the battery back on the car make sure it still above 12.65v reading otherwise your battery is bad.
12-17-2010, 12:42 PM | #13 |
Rep 4
Well, the BMW service told me the whole control unit needs to be replaced.
This thing costs 500+ euros if new (I live in Greece)... I just purchased a used part from eBay, and will try to place it myself when it arrives, it shouldn't be that hard, it just has a screw on top and two connectors at the back as far as I can tell by the blueprints (I bet BMW would charge me 100+ euros just for the placement)... I hope Paul this is not the case for you and the thing is not broken like mine. |
12-17-2010, 02:40 PM | #14 | |
180
Rep 659
Chris
12-17-2010, 02:42 PM | #15 |
180
Rep 659
How long did you disconnect for? Try overnight.
The lack of Auto Up/Down windows is normal any time you disconnect the battery, the sensors do not know where the window is. There is a sequence you have to do to bring them back (search the forum, I've forgotten the sequence). As mentioned above, check any Fuses that deal with the Climate Control. Chris
12-17-2010, 05:33 PM | #16 |
18
Rep 74
It turns out my car was in transport mode. BMW charged me $60 to turn that mode off and told me I have a bad cell in the battery. They want $425 for a new battery plus an hour labor. Took it to auto zone, they said the battery tested fine. Now I don't know what to do.
12-17-2010, 06:31 PM | #17 |
479
Rep 2,782
Does the climate control work now?
I've left on lights before, and the car usually shuts them off when it senses a drain. |
12-17-2010, 09:26 PM | #18 |
Dog Listener
704
Rep 7,850
Does that work on the M, or the 3.0? Wife left the lights on today on the ///M, and the battery totally crapped out. Had to have AAA jump it. Battery did take a charge, but is at the end of its life (have to replace it this weekend). So perhaps that's why the feature didn't work (current drain cutoff assumes a certain level of battery capacity, battery is more or less toast, it didn't catch it in time....).
12-18-2010, 01:02 AM | #19 |
Engineer
216
Rep 2,122
12-18-2010, 02:46 AM | #20 |
Rep 4
Check this out: http://www.bimmerforums.co.uk/forum/...roblem-t44239/
Exact same problem, "transport mode" the issue. God I love Google. I will visit the BMW service asap to check it out. |
12-18-2010, 04:49 AM | #21 | |
479
Rep 2,782
Interestingly, when the battery started to crap out on the 3.0i it gave me fair warning. The car started weaker and weaker each day for several weeks; if this ever happens to anyone else, replace the battery ASAP because I ended up killing the starter as well. With the M, I went to start it one day and it was completely dead. No warning at all. The windows wouldn't even seal closed after closing the door. Each time I opened and closed the car door they would dip down a bit but not have enough power to go back up. By the time the tow truck arrived, they were at half mast The driver of the tow truck made me feel like an idiot. He asked me to pop the hood to jump the car, and when I explained that the battery was in the trunk he pointed to the positive terminal near the firewall. I'd been pulling apart my trunk to trickle charge my 3.0i for years for no reason |
12-18-2010, 10:47 AM | #22 | |
1136
Rep 2,867
Drives: Anything
