12-09-2010, 09:08 AM | #1 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Advice (VANOS/service related)
So, here is the deal. My SES light came on last week so I scheduled an appointment. Codes said it was a VANOS issue and they reccommended a flush (they said with something similar to seafoam but BMW reccemmended). They also apparently deemed it necessary to perform an oil change (for $122) with this service. First question, do you HAVE to do an oil change with this flush. It was rang up as a separate service so I don't think so. I just had my last oil change in October which cost ($90) and it was not covered under warranty since they had conveniently changed their service policy and I had driven 8,000 miles since my oil change in October of 2009.
So, they decided to do another oil change, charge me more than usual for it even though it has only been 1.5 months and ~1,000 miles since my last oil change I paid for. They said the flush worked and everything was cheddar, so I was happy, no more codes. On my drive home the SES light comes back on. They seem to think the VANOS will need to be replaced now since the flush did not work. Does anyone on here have any suggestions. I have completely lost faith in my dealer at this point.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
12-09-2010, 10:11 AM | #2 |
Bad Lieutenant
233
Rep 3,517
If the "flush" worked, sounds like they figured you had some sludge buildup? I call BS on the need for an engine flush, they should have addressed the VANOS first if it was the first issue discovered, no?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
12-09-2010, 10:19 AM | #3 | |
140
Rep 1,991
12-09-2010, 10:59 AM | #5 |
42
Rep 632
+1 sounds sketchy, flush for a VANOS problem. And what is "VANOS problem" anyway, that is vague - they should be able to tell you more specifically what the code indicated.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
12-09-2010, 11:20 AM | #6 |
2070
Rep 4,365
Oh sorry. My last oil change was in October at 49,750 miles and I am currently at 50,500 miles and my first Service Engine Soon light appearance. Another reason I am so aggrevated.
I will type in more detail what the sheet said the issue was when I get home.
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded Last edited by Hawkeye; 12-09-2010 at 11:28 AM.. |
12-09-2010, 12:32 PM | #7 |
140
Rep 1,991
So you are just out of warranty... They should be giving you a goodwill repair on this one.
12-09-2010, 01:04 PM | #8 |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
What were the codes?
12-09-2010, 04:28 PM | #9 |
2070
Rep 4,365
This dealer is apparently not the goodwill type, or at least this new SA isnt. The last SA was awesome, and was the reason I switched all of my vehicles to their service department. Oh well.
I will look and let you know the codes when I get home, not positive if they noted them though.
12-09-2010, 04:31 PM | #10 |
218
Rep 4,726
Ummm.... what did they flush.... I will bet one of my little guys you got ripped off....
Sorry. Dealers are the least trustworthy of any.
12-09-2010, 04:55 PM | #11 | |
2432
Rep 11,667
They flushed your wallet.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
12-10-2010, 10:26 AM | #12 |
2070
Rep 4,365
Okay, apparently they did not note the code but the writeup on my work says this...
"Short tested, recieved faults for vanos intake and cam sensor reference for exhaust. Followed test plans, cam sensors wiring and both reading ok now. Most likely cause vanos solenoids sticking/soiled. Performed vanos solenoid flush with test plan, reaching all target values now. Functioning correctly, advises changing oil now. Cleared all faults and found oil service flush on line. If faults return, solenoids will need replaced."
