ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      11-19-2010, 12:21 PM   #1
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
Front Grill Support / Bracket?
While washing the car the other day I noticed one of my grills is not secure, you can easily push it back, basically wont stay in place. Does anyone know what part locks the grill in place? Going to pull the bumper off anyway for other work so figured I might as well fix this while I'm at it..
Couldn't identify any part here (unless I'm looking at the wrong diagram):
http://realoem.com/bmw/showparts.do?...47&hg=51&fg=15
Follow for latest mods
      11-19-2010, 01:28 PM   #2
Flying Scotsman
Flying Scotsman's Avatar
Drives: BMW Z4 2.5L
Grills are one piece, little tabs on them can break off over time. Old car had this problem, exactly like you have described, right down to when washing the car they would pop out. Grills never fell out in the time i had the car so i never renewed them.
You could use it as an excuse to replace them with all black or carbon grills lol.
      11-19-2010, 01:45 PM   #3
3002 tii
3002 tii's Avatar
2286
That's weird b/c both my aftermarket and oem grills have the same problem. This is for the left grill only, and both of them push through. I'll try to take a closer look but I'm pretty sure the oem one has no broken tabs...
      11-19-2010, 02:15 PM   #4
Flying Scotsman
Drives: BMW Z4 2.5L
Only thing i can suggest is IF there is no broken tabs, then wrap some electrical tape round these tabs where they meet the bodywork to hold them in place with a better "bite" if you know what i mean.
      11-19-2010, 10:28 PM   #5
3002 tii
3002 tii's Avatar
2286
So I popped out the grill, inspected the grills and tabs are all fine. What the problem is (as I suspected) is that there's plastic frame that sits behind the bumper that "accepts" the grill. That is the piece that's NOT secure. I inspected the other side and that side is secure and tight, but this side almost slips off or disconnects from the bumper.
I checked realoem but I couldn't find this piece... is this part of the bumper and cannot be bought separately? It would seem that you can or should be able to purchase this piece separately since I see how it slips on and off (there are these plastic "prongs" that the frame slides over)...
      11-20-2010, 11:28 AM   #6
3002 tii
3002 tii's Avatar
2286
bump for update, figured out what's wrong... anyone know if this piece can be purchased separately?
      11-20-2010, 03:47 PM   #7
Ron Stygar
9
Drives: 2006 Z4 M Coupe
The part is part of the bumper. When you push the grille and it's not lined up it pushes it out. I glued mine all around between it and the bumper.
When you install now put your fingers behind the part that came apart and squeeze it in with the grilled assuming you have it in line.
      11-20-2010, 03:56 PM   #8
3002 tii
3002 tii's Avatar
2286
When you glued that piece to the bumper, was it because yours also got damaged? Are you saying at one point if the grill was installed (or attempted to be installed) incorrectly where it didn't line up correctly, the result would be that piece becoming damaged / disconnected?
That might sound right because I recall when I first purchased RPI scoops way back, I had trouble lining it up. So I later brought it to a shop while getting other work done and I recall the tech having difficulty with the grill, and I think he might have just used brute force to get it in...
But even without the grill in place, I can push that "frame" back effortlessly with my index finger. Or are you saying once I glue the frame to the bumper, then ensure the grill is lined up and that should solve my problems...
      11-20-2010, 05:07 PM   #9
Ron Stygar
9
I had some body shop stuff and when I pushed it in the piece moved.
There are some pins coming from the bumper that the black piece goes onto.
And the metal pushes down the pins to hold it on. When I gued it where the pins were it still came apart. So I glued the front of the black piece to the bumper. From that with the squeeze no problem.
      11-20-2010, 08:41 PM   #10
3002 tii
3002 tii's Avatar
2286
Ahh gotcha, same problem I have nothing keeping the frame from sliding off those pins. I will glue them down, thanks Ron!
      06-18-2012, 08:54 AM   #11
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Well I am having the exact same problems except I believe I am screWed because the mounting bracket thing is broken my grills are new because I got them in the mail but the mount is broken on 1 of the sides
      06-18-2012, 09:07 AM   #12
3002 tii
3002 tii's Avatar
2286
Just glue the bracket back to the bumper, that's what I did. Works fine...
      06-18-2012, 09:09 AM   #13
Z4-VILLA
Afghanistan
111
epoxy?
      06-18-2012, 10:06 AM   #14
3002 tii
3002 tii's Avatar
2286
epoxy?
that's what i used...
zpost
