ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      11-17-2010, 09:58 AM   #1
Z4MHawk
Z4MHawk's Avatar
Drives: '06 Z4 M Roadster
Rattle!
I have a rattle in the dash...and before I go Schwartzenager on it I thought I would ask the experts! Appears to be coming just below the front window vents and above the Tach. I can't get a good view down the vents to see if it is a loose coin or something in the vent itself. Sounds like metal on plastic...and occurs on rough road surfaces. Any ideas on how to proceed?
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
      11-17-2010, 10:02 AM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
If you pull the vent out you can get a pretty good look behind there. It might be one of the clips that hold the trim piece on.
Straightaways are for fast cars, Corners are for fast drivers.
      11-17-2010, 12:15 PM   #3
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
Did you get your Strong Struts installed? I noticed some rattling in the engine bay area after installation of mine. They are mailing me additional washers and are fairly confident it will help.
      11-17-2010, 03:23 PM   #4
Z4MHawk
Z4MHawk's Avatar
Funny you ask...the rattle did start after I stalled the struts but I ended up using the OEM flange nuts on my studs and they are tite. Also, this rattle is sharp and I can't imagine the sound thru the firewall would be that sharp. I will check tonight!
zpost
