11-13-2010, 11:58 AM | #1 |
55
Rep 1,224
Eibach Spring Install-More Frequent DTC Activation?
Recently installed a set of Eibach springs on my 07 sport suspension Coupe. Drop front was 0.5 inch and rear was 0.25 inch. I have not yet had the car aligned. Everything is properly torqued and no unusual noises. I was careful to not to damage the front ride height sensor during the install. My problem: I have noticed that when accelerating/turning onto my usual freeway onramps the DTC seems to be activating more frequently then before the spring install. I was wondering if:
1. The change in ride height front to rear is being interpreted by the leveling sensors as suspension change by the DTC programming? (Any way to adjust sensors?) 2. If somehow I damaged the front or rear leveling sensors? (How to diagnose?) 3. Is this simply a prealignment condition? 4. An aspect of the spring rate? (Any help by larger swaybars?) 5. Am I pushing the car harder and not realizing it? (It really is fun to drive!) TIA
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
11-13-2010, 12:43 PM | #2 |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
It was my understanding that the DSC is based on wheel speed and accelerometers. The higher-rate springs may be causing the car to have less traction as it passes over bumps in the road.
11-13-2010, 02:17 PM | #3 |
Car Geek
3626
Rep 3,594
This is most likely the case. This is a noticeable trait of the Z4M when accelerating hard across an intersection when crossing the ruts left by heavy trucks - lots of momentary flashing of traction control light.
11-13-2010, 02:20 PM | #4 | |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
You should find out the eibach spring rates. OEM are progressive so no set number but it's probably near the 300 mark, time to get the LSD man! Haha |
11-13-2010, 02:22 PM | #5 |
55
Rep 815
If you didn't change/adjust dampers when you installed stiffer springs I would think that there could be excessive rebound causing the loss of traction seen. (Time for the Koni Yellows?)
PS. Since most of us are following the same thread on multiple forums, should we just consolidate our replies either here or to the longer/older thread on Bimmerforums? |
11-15-2010, 04:00 PM | #6 | |
55
Rep 1,224
Thanks to all who posted.
