KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
11-13-2010, 12:52 AM | #1 |
68
Rep 531
Will 235/35R19 Tires fit 245/35R19 Wheel?
I can't seem to find a snow tire for the stock 19" M3 front wheels.
Would the 235/35 19 tires fit the stock 19" wheel?
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
11-13-2010, 06:17 AM | #3 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
it's fine
11-13-2010, 08:06 AM | #4 |
2745
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
I would go with 255/35/19 front tires. That's what most people install on the stock 19" wheels. I think Bridgestone makes a snow tire in that size.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
11-13-2010, 08:52 AM | #5 | |
68
Rep 531
i'm just double checking. i find it so odd that no one makes a 245/35 r 19 snow tire
11-13-2010, 06:08 PM | #6 |
2745
Rep 6,734
I would not run a 235 in the front. Tire rack often recommends conservative tires and offsets. As you probably know, a 235/35 will have an even lower profile than stock which I would not want on our mn pot hole roads. Plus the 235's have less rim protection due to the narrower size. You could then run either 255 or 265/35's in the rear.
'23 X7
11-13-2010, 11:28 PM | #7 |
BimmerPost Supporting Vendor
1007
Rep 4,619
11-15-2010, 07:29 PM | #8 |
1771
Rep 7,653
For snow, i recommend the following combination:
235/35-19 front and 255/35-19 rear. narrower is better on snow. Allows for better siping of the slush and snow out from under the tires. especially for those that actually drive through deep snow. For just wet and Dry traction on colder temperature, wider can work too. But generally, i would recommend the narrower. Also, the winter/snow tires are constructed differently and their 235/35-19 will look a little different from regular 235/35-19 on the same wheels. for the 19" snow, there are only 2 really good options (for staggered fitment). 1 by Blizzak LM60 and the other by Vredestein Wintrac Extreme.
11-17-2010, 02:04 PM | #9 |
M3Post Supporting Vendor
87
Rep 964
Bart, now that is stretching! When I say "maybe a little stretched, but not VW tuner stretched" this is the stretch that I am talking about.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
11-17-2010, 10:09 PM | #10 |
1007
Rep 4,619
