11-09-2010, 12:32 PM | #1 |
49
Rep 320
Want to upgrade turbos!!!!
Anyone knows if any company has made upgrade turbo kit for 135i
Current- 2009 M-Sport 135i
SOLD-2008 135i(Jb4-15ohm-FSB)map 3 @ 19psi, Active Autowerke Charge Pipe with Dual meth nozzle cm5 & cm10, Active Autowerke Intercooler, AFE Intakes, Active Autowerke DP with RR Catback exhaust and KW V2 coilover. |
11-09-2010, 01:20 PM | #2 | |
103
Rep 3,177
helix and rb will likely be your best bet. check e90post or n54tech for the threads and info to put a deposit. you'll need core turbo's unless you want to take yours off and wait while the company upgrades them. or, wait until hpf or ar design release their single turbo conversion. i think ar design are closer to selling a kit, but it's going to be over $10k most likely |
11-09-2010, 02:49 PM | #6 |
200
Rep 2,799
thanks to MGallop |
11-09-2010, 03:09 PM | #8 | |
49
Rep 320
11-09-2010, 03:46 PM | #11 | |
7
Rep 285
1. charge pipes and a larger intercooler 2. possibly larger injectors 3. tune 4. possible custom fabrication for exhaust? And if you're finally putting down a lot more power, you have to worry about the transmission, drive shaft, rear diff, and rear axles breaking. Not to mention the slew of motor problems you potentially run into doubling the psi the stock turbos dumped into the cylinders. The turbo kit won't cost $10k, but I'll bet you double it's cost getting the rest of your car up to snuff. In my experience, once you step outside the realm of conservative tunes using stock parts and start adding larger turbo's to any car, the cost goes up...exponentially. Cliffnotes: You think it'll cost $? It'll actually cost $$$$$. |
11-09-2010, 03:53 PM | #12 | |
11
Rep 685
Drives: 91 300ZX Twin-Turbo, 2010 135i
The only thing I could see breaking at this point would be the axles, considering they have already snapped on people that are lowered and running drag radials while doing hard launches. |
11-09-2010, 04:08 PM | #14 | |
103
Rep 3,177
and there's that's not even accounting for other, misc items that will add up quick while you're doing the build. things like: -new exhaust manifold gasket -vacuum system components -heat wrap -etc etc etc i went through a turbo build on my last car. even though i never completed it i added up enough receipts to know how much a true turbo conversion costs. |
11-09-2010, 04:18 PM | #15 | |
7
Rep 285
11-09-2010, 04:33 PM | #16 |
Resident Kerbalnaut
477
Rep 10,703
Ummm the ar kit only runs 14-15 psi...
The engine was built for over 400hp the transmission can handle 450 hp on the stock clutch. The weak link are the halfshafts...easy enough replacement |
11-09-2010, 04:46 PM | #17 | |
11
Rep 685
That turbo is capable of much higher boost levels while being efficient. Actually, you can't go below 14psi unless you change the wastegate spring on it. |
11-09-2010, 05:12 PM | #18 | |
Resident Kerbalnaut
477
Rep 10,703
If you want much more power than that there is ^no satisfying you. While I don't think an N54 car will be like a 1200 supra ten years from now I have ^no doubt that we can make high power reliably. |
11-09-2010, 05:25 PM | #19 |
200
Rep 2,799
as of now there's no knowing what's going to happen until some more tests are run with higher boost. that turbo they're using is good for 700whp, i'm not saying the n54 can handle anywhere near this much power, but as of right now its not too certain if i can't handle anything around 500whp
thanks to MGallop |
11-09-2010, 05:44 PM | #20 |
11
Rep 685
500whp has been broken, on nitrous. With proper fueling and a properly sized turbo there should be even less to break or cause issues while trying to hit 500+whp.
Once the N54 blows apart people will start custom sleeving and using forged internals anyway. It shouldn't be too hard to eventually get 1000whp out of a 3.0L I6 like the N54. |
11-11-2010, 07:25 PM | #21 |
Rep 28
I have the ASR turbo upgrade, whent to the dyno yestarday 427whp and 446 torque. The tempeture was around 85 degres, the procede is retanding 5 degre,because of the air intake temp. I will go next week for more testing. Check n54tech forum to view the dino chart,
11-12-2010, 10:05 AM | #22 |
49
Rep 320
IS THAT THE MAX AND HOW MUST BOOST?
