10-30-2010, 08:38 PM | #1 |
38
Rep 456
128i performance brakes + painted rear calipers to match
Another 1addict member asked me for some pictures and I thought why not put them up for anyone else that is interested. So here you go! This is my 128i with the performance brakes and the rear calipers painted to match courtesy of g2usa.com.
The material of the caliper is different, so it looks a little darker, but the difference is very subtle and not easy to see unless you are told its there. Overall I think its a nice touch and I am happy with it. |
10-31-2010, 02:03 PM | #4 |
699
Rep 3,267
Drives: 2010 128i
Alow,
So I guess the 128i Performance brake kit only includes rotors, calipers, and perhaps steel brake lines for the front brakes? Nothing for the rears? Thanks. |
10-31-2010, 10:01 PM | #5 | |||
38
Rep 456
- Front calipers & pads - Front rotors - Front dust shields (bigger to match bigger rotor) - Brake pad wear sensors (front and rear) - Rear calipers & pads - looked the same as stock, but had different part number so I put them on - Rear rotors I think that's it. no SS brake lines. |
11-01-2010, 02:07 AM | #7 |
761
Rep 7,408
I am really interested in this setup as well, but dont want to change the rotors/pads yet.
Do you think I can use the performance calipers on the front 128 stock rotors and pads? |
11-01-2010, 12:50 PM | #8 |
38
Rep 456
I am going to say no, since the perf. rotors are bigger, and the pads are completely different shape.
11-02-2010, 05:00 AM | #9 |
699
Rep 3,267
Drives: 2010 128i
Okay, so rear rotors, although not cross-drilled or slotted, are in fact larger in diameter?
And rear calipers and pads are replaced with units that look more or less identical but carry a different part number? Interesting - I wonder why the change with these? I'm cosidering this kit in the future, just trying to justify the cost (although it looks like the price has come way down, so I may not need much of a nudge after all). |
11-02-2010, 07:17 AM | #10 |
I no longer work for United BMW!
308
Rep 3,330
Drives: E46 M3, E46 330i ZHP, E36 325i
Looks awesome
BMW CCA, PCA, & CHIN Motorsports Instructor.
11-02-2010, 07:18 AM | #11 | |
38
Rep 456
I think rear rotors are exactly the same as stock. But don't quote me on that.
And yes, calipers and pads have different part numbers but look the same. Ya the price has come down a lot! If you install it yourself, it's not bad at all. Quote:
11-02-2010, 07:39 AM | #12 |
699
Rep 3,267
Drives: 2010 128i
Cool - thanks for the info.
I just can't figure out why the rears are being replaced with this kit if there's no change...maybe Dan or another vendor can chime in? |
11-02-2010, 12:56 PM | #14 |
7
Rep 285
Read my post. They should be replaced. Any time you add larger calipers or better performing brakes to the front of your car, you're completely throwing off the stock brake bias. A full brake kit should include both front and rear calipers/rotors that were designed to work together.
11-02-2010, 04:47 PM | #15 | |
699
Rep 3,267
Drives: 2010 128i
11-03-2010, 04:54 AM | #16 |
699
Rep 3,267
Drives: 2010 128i
Bump.
No one knows what the difference is (if any) between the stock rears and the Performance rears? |
11-21-2010, 01:05 AM | #17 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Bob,
According to Dan the performace rear is pretty close to the 128i spec, basicly you only benefit from the front there is not much difference on rear.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
11-21-2010, 07:15 PM | #18 |
44
Rep 1,003
According to BMW's website, the 128i Performance Brake Kit only includes front brake hardware. This leads me to believe that the kit is designed to work with the OE rear brakes.
11-21-2010, 07:22 PM | #19 | |
117
Rep 1,998
The answer to the question is the following: The rear rotors and pads that come with the perf. kit are exactly the same part number as stock rear pads and rotors that come oem the rear caliper is of the same design as the rears, ie cast iron, and exactly the same mounting points and fitting location. The difference is the diameter of the piston. we measured the outside of the piston housing and compared it to the one we took off. its about a 1/16th of an inch wider in diameter, hence the piston in its self must be larger. The brake sensor is also different. I suspect this is how they addressed the brake bias between the new front 6 piston brembos to the rear. The instructions say also that the car needs to be "retrofitted" using the BMW programming station. we assume this tells the abs /dsc /dtc etc that Hello..we have better brakes and adjust accordingly while using those functions. On the track they were fade free...did an amazing job slowing me down on the front straight, ( top speed of 122 ) for the harpin, and did not get spongy, smokey, long, or overheated after 40+ laps... i drove home 3 1/2 hours directly after that event with no issues... street braking after that was much better as they were well broken in by then. i ran 2 events prior with the stock brakes, and they were way more spongy towards the end of the day. I used stock fluid all three times and inspected the pads and rotors when i took them off to put the new ones on. they were not glazed nor were the edges of the pads fried or bubbled. Also rotors were not warpped, but i suspect they woudnt of lasted 6 events a year. over all for the price i think they were well worth it. As far as the fronts go, the calipers are of similar design to the 135 brembos, the rotors look great,stayed cool, stayed quiet, and seemed to be better than the stock 135 rotors...i say this because my friend that came with me ( with his 135), warpped his rotors. the brake pads are not the same number as stock 135 pads, so there must be some difference there also. he was reaching 135ish on the front straight, and maybe was going too hot into the hair pin, none the less he beat my best time by 4+ seconds..... man he really could accelerate coming out of a corner... i was chasing tail lights the whole time...lol
X1, R58 JCW, M2 in my future if planets align
11-21-2010, 07:27 PM | #20 | |
117
Rep 1,998
the 128 kit p/n ending in 722 includes everything front and rear as said before. look here .. http://www.realoem.com/bmw/showparts...80&hg=34&fg=95
