10-10-2010, 02:43 PM | #1 |
Rep 57
Low Oil Level on 35d
I check my oil level on a regular basis and was surprised today when I noticed a significant drop over a short period of time (2 weeks). I just reached 8,900 miles and my oil level is reading a fraction above min. Two weeks ago (and probably 8,200 miles) it was reading 3/4 full.
This information is per the electronic reading. I have not had an oil change since delivery in June (4.5 months ago), largely because of BMW's recommended interval of 11k for first change. I'm wondering if anyone else has experienced this on the 35d and if anyone knows what the potential reason behind this drop may be? This is my first diesel, so I don't know what to expect.... Thanks! |
10-10-2010, 03:24 PM | #2 |
866
Rep 5,452
Maybe that is why they call it an 'Oil Burner'
BMW would consider that normal oil consumption in any of their motors - 1-2 qts between oil changes is what BMW calls normal and you probably need about a half - 1 qt to top it up. It is also pretty new and any engine tends to burn a bit when new, these engines are broken in on synthetic oil which takes a bit longer than it used to with conventional oil to fully seat the rings etc, so a qt in the first 10k is certainly not out of the ordinary. The diesel may even burn a little more with it's higher compression and running temps.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
10-10-2010, 11:35 PM | #3 | |
197
Rep 1,180
When you measured your oil level most recently, was your X5 parked on level ground and was the engine warmed up (for at least 10 minutes) before you used the electronic reading ? Why BMW supplies a good old dipstick for this engine in the 335d and switches to electronic reading for the X5 is a mystery to me. The former method is so much faster and more reliable than the frustrating electronic device.
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
10-11-2010, 09:59 AM | #4 | |
Ski bum
317
Rep 6,198
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
