09-23-2010, 08:37 AM | #1 |
All I do is Win... Eat Race Sleep
152
Rep 2,184
Drives: 2018 Range 2011 M3 2019 600lt
For those who got a reflash
So i am getting a reflash this weekend for a completely turned off check engine light and i like to know how many of you got a reflash for this issue?
Did any of you guys get any other check engine light after it was turned on again?
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888 F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires |
09-23-2010, 09:01 AM | #2 |
58
Rep 954
Who are you going with? Gintani? If so, do you know where the guy is or do you have his contact info? So far I haven't seen any engine light.
11 335is, KW1, M3 bits and what not
08 M3 Sedan 6mt, loaded, modded to the bone Old: 04 M3 SMG |
09-23-2010, 09:21 AM | #3 |
102
Rep 2,037
Make sure they turn on your O2 sensors as they are probably turned off. I also see you have the Fabspeed pipes so make sure you have the O2 extenders on too. If you dont have these things done then you will get CELs. Also, if you get a chance do a dyno run before they reflash and then do one after.
09-23-2010, 11:46 AM | #4 | |||
152
Rep 2,184
thanks alot i will get the O2 extenders put in by fabspeed. i have a pre flash dyno i put down 360 hp and 265 tq.. but i will re dyno after Quote:
09-23-2010, 04:55 PM | #5 |
17
Rep 246
I have OE Tune. I had it done back in August after my 1200 mile service. I dont see my CEL light come on either on start-up. So i guess I have the tune already for HFC or Cat delete. Its not something i really wanted, although the car does run great. Far as I know the CEl light would only come on for an emmisions issue, so other than that i dont think you would have that many it issues with the car. I did buy there EZ Flash and hopefully i did the download right and i have the factory tune stored. This way if the car does become un-operational, i could swith back to stock and go to the dealer. Do you really think the dealer is going to look for dash lights when you go there for routine maintaince? How many M3's do you think these techs actually see? So if my light is already turned off, then I should not have an issue when i add Gintani's HFC's. Any person have experience where the dealer said something? Did they re-flash your ECU without asking?, Put on there BMW tuner lock?
09-23-2010, 05:00 PM | #6 | |
46
Rep 891
09 SG E90, Black on Carbon Leather, Tech, Premium, Cold, iPod, Premium Sound, 19s, OEM Alarm, PDC, Moonroof, Sirius
Eisenmann Sport / Eibach Springs / 35% F1 Pinnacle Tint / Macht Schnell Air Filter / LUX Angel Eyes / Black Grill / AA Pulley / Powerchip Stage II Tune / Fabspeed X-Pipe & HFC / RAC Monolites RG63 |
09-23-2010, 08:43 PM | #7 | |
12
Rep 214
09-23-2010, 08:56 PM | #8 |
46
Rep 891
Do you still have your stock Cats or have you modified your Cats?
09-23-2010, 10:34 PM | #10 |
12
Rep 214
09-23-2010, 10:37 PM | #11 |
501
Rep 4,033
That is not correct, with the OE tune, when something the ECU does not like occurs, you will get a warning light and if necessary the ECU will enable "safe" mode.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
09-24-2010, 06:26 AM | #12 |
46
Rep 891
If this can be confirmed, then it is very awesome. No one can fully confirm this though.
09-24-2010, 06:49 AM | #13 |
152
Rep 2,184
agree need it for my fabspeed cats cuz they throw codes for days...Mike at PC said "its a simple change from a 1 and a 0" as he said to fix the cel..i got a question does the car still throw codes if your cel is completely off ?
09-24-2010, 07:42 AM | #14 |
46
Rep 891
I don't know the details of how to fix it, but if the CEL is off it will not turn on for ANY reason. To answer your question it depends, there was an issues where the CEL was turned off but codes were still being thrown and stored in the ECU, but you would not know it, since the CEL was turned off.
09-24-2010, 08:14 AM | #15 |
12
Rep 214
09-24-2010, 08:15 AM | #16 |
12
Rep 214
From what I've seen they have two options, "on" and "off" nothing in between. So catless guys will have issues.
09-24-2010, 08:17 AM | #17 |
46
Rep 891
Since your a 2010, you have not had to pass emissions. I would be really interested to hear from someone that has passed emissions with a tune. That is the true test. Passing emissions and the readiness test.
09-24-2010, 08:29 AM | #18 | |
12
Rep 214
I have independently tested the readiness/faults over the last few months. PM me an email of my bavarian technic screenshot for my current or lack-of-fault codes and heldhand readiness monitor if you'd like. |
09-24-2010, 08:32 AM | #19 | |
501
Rep 4,033
What's wrong with you? It may very well be a red flag on start up, I wasn't referring to that. Yes certain things are disabled or tweaked, like the rear 02's, so you don't get a light, but what I said is accurate. You don't run OE tuning, no the SES light does not appear before start up, BUT if the ECU detects something you will still get an engine warning light, or notified. Just like any other car should, an engine light appears in the nav screen and on the dash, and if necessary the car will go in limp mode until you recycle the ignition.
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH Last edited by DLSJ5; 09-24-2010 at 09:27 AM.. |
09-24-2010, 08:53 AM | #21 | |
501
Rep 4,033
Ben, I can assure you even with the SES light disabled for specific things or if you don't see it before start up, if the ecu detects certain things you will get a warning light, the light will go away after you recycle the ignition.
09-24-2010, 09:27 AM | #22 | |
46
Rep 891
Turning off the rear O2 sensors is a totally different thing. If you do that correctly, the functionality of your CEL stays intact. It will light when you start the car and it will also go off if there are other codes besides the ones thrown by the rear O2 sensors. Problem is this, there are many tunes out there including the one that I have before it was corrected that turned off the CEL completely, worse yet some left the O2 sensors still on so the car was still storing codes but you never knew it as the CEL was turned off completely. The only way to know is to use a OBD-II diagnostic tool. I repeat, ANYONE THAT HAS THEIR CEL COMPLETELY TURNED OFF IS RUNNING A HUGE RISK, NOT ONLY FROM ISSUES THAT ARISE FROM NOT KNOWING WHEN THERE IS A PROBLEM WITH THEIR ENGINE, BUT ALSO FROM DETECTION FROM A DEALER THAT YOU HAVE TAMPERED WITH THEIR ECU. These facts are un-arguable.
