08-27-2010, 06:38 PM | #1 |
44
Rep 567
Enabling rear fog lights on a US spec 1 series
Has anyone tried the part below? On a car with Xenon lights, it supposedly enables the rear fogs, which are apparently already installed.
I asked my local dealer about this switch set, and they can not even order it. http://www.turnermotorsport.com/html...ID=61316932796 |
08-27-2010, 06:43 PM | #2 |
53
Rep 1,477
08-27-2010, 07:55 PM | #3 | |
2148
Rep 10,176
08-27-2010, 08:17 PM | #4 |
European Editor
10589
Rep 22,992
On a side note... do the US spec cars have the little motors in the headlights to adjust for rake/load? Like when the back of the car is loaded up with crap... the headlights will point up some... on the euro cars there is a switch that can tild the headlights DOWN for just such events.
I was wondering IF installing an Euro headlight switch with the adj headlight height would make the lights point down when needed? I think the US lights might be totally different animals for the euro-zone lamps(clear). Just wondering. |
08-27-2010, 08:23 PM | #5 | |
2148
Rep 10,176
08-27-2010, 09:07 PM | #6 |
44
Rep 567
You are right. I didn't do a search. I figured it was a very esoteric question. In fact, the LeatherZ guy seems to have better pricing on the switch than Turner Motorsport. Looking there now.
08-28-2010, 04:13 AM | #7 | |
European Editor
10589
Rep 22,992
The switch allows the driver to angle the headlights DOWN. I also find it useful in foggy conditions. My car does not have it, But I see there are like four or five versions of this euro headlight switch on RealOEM. So I was wondering IF it is just a switch swap... or IF I would also need to headlamp units too? To have that feature. ??? |
08-28-2010, 04:21 AM | #8 |
698
Rep 3,267
Drives: 2010 128i
Mike, just FYI, your dealer can't order it because several months ago BMWNA began prohibiting them from ordering euro-spec parts. I was going to suggest Leather Z, but it looks like you already found them.
____________________________ |
08-28-2010, 04:25 AM | #9 | |
698
Rep 3,267
Drives: 2010 128i
08-28-2010, 05:38 AM | #10 | |
European Editor
10589
Rep 22,992
I guess I should just drop my my German dealer and ask them. |
08-28-2010, 06:04 AM | #11 |
210
Rep 959
Xenon lights have auto level, I think Halogen(regular lights) have the manual adjustment
08-28-2010, 07:56 AM | #12 | |
2148
Rep 10,176
08-28-2010, 10:04 AM | #13 |
44
Rep 567
On the auto level, my car seems to think the lights need to be farther down than I want. That would be the primary reason for being able to manually adjust this. It is funny how the US is supposed to be a tehnically savvy population, yet there are many aspects of our BMWs we can't fiddle with...
08-28-2010, 10:11 AM | #14 |
European Editor
10589
Rep 22,992
Hi Guys,
I realized that the euro cars WITH xeon's do not have the height leveling switch adjustment. Only cars with regular halogens have this adjustment switch. Here is a pic of Oli's friend with a 120d with Xeon's. His car has no adjustment switch. Only switches from front and rear fogs. So the car must adjust for this automaticaly. |
08-28-2010, 10:38 AM | #15 | |
215
Rep 1,489
-Diplomacy is saying, "nice doggie while trying to find a rock"-
07-Z4 coupe-Black/Black/6MT/sport/premium/X 04-M3 vert-Black/Imolla/6MT/Cold/Xenon/HK/ 06-M3 Coupe-Mystic/Black/6MT/ZCP/Xenon/HK/ 09-135i- AW/Bk-Lette/6MT/M-pac/Nav/Hi-Fi/Usb-Ipod/SOLD |
08-28-2010, 11:02 AM | #16 | |
Car Geek
3626
Rep 3,594
10-04-2010, 04:26 PM | #17 |
European Editor
10589
Rep 22,992
Hi Gang,
Just did this mod today. It was fairly easy. Now I have my rear brake fogs! The only thing I would add to the DIY directions is to remove that side pannel from the end of the dash/door area first. That pannel kind of holds everything together. Also I used a plastic pry bar (interior tool) to get my fingers under the dash vent. You really must pul straight up and dam hard. Feels like something will break, but everything is fine. I ordered the switch from my local BMW dealer. 61 31 6 932 797 The switch cost me 67 euros. Be aware that there are SEVERAL versions of this switch. You need to know IF your car has> Xeon, Rain Sensor & front fogs. For my 135i thats: Yes, Yes and NO! new switch... rear fogs OFF... rear fogs ON! |
10-04-2010, 04:33 PM | #18 |
49
Rep 469
Drives: BMW 16' M3
Nice!
10-04-2010, 07:29 PM | #19 | |
The Only Sane One Here
61
Rep 1,135
Just depress both of the spring clips, and then gently pull upwards on the bottom edge of the vent (at the front of the dashboard). It will lift up pretty easily, once the spring clips have been released. You don't need to lift it much - it only needs to swing up a bit to give you access to the 2 screws below it. When you go to reassemble it, just press the vent back in place, and the spring clips should pop back into place too. For 135i owners: It's OK to get the one with the extra switch for the front fogs, if you want. It'll work just fine, even tho you don't have front fogs. When you press the switch, the dash indicator will light up, and you can pretend you have front fog lights.
2011 135i VERT SGM/SB/MOONLIGHT - ED - with every single friggin' option they offered.
10-27-2010, 04:21 PM | #20 |
Rep 28
Now that you have rear fog lights, please use them appropriately. That means in dense fog, where someone might not be able to see your car at all without them. I have driven on the freeway too many times on clear nights and come across someone with a car with the rear fog lights on. Rear fog lights are uncomfortably bright for drivers behind you in these conditions and may also make harder to see your brake lights.
I have family in England and spent a year working over there. Over there, if you drive with your rear fog lights on when they are not needed, you are grouped in the same category as someone who drives for miles and miles with a turn signal flashing... |
10-27-2010, 04:36 PM | #21 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
Guilty of turning on my rear fogs to distance tailgate drivers.....
10-27-2010, 04:53 PM | #22 |
44
Rep 567
I would like that cubby option! Anyone know the part numbers for it, in grey?
ECS Tuning had the fog light switch. It was not hard to install, just a little under an hour. The switch is smart, won't turn on the rear fogs unless the parking or headlights are on and the front fogs are on. Makes it a little tricky to use as a method to discourage tailgaters. (test mode on an SLR pro flash is good for that!) |
