08-23-2010, 04:24 AM | #1 |
102
Rep 1,552
Drives: '19 M2C | '20 100AE ND2
DCT Launch Control Update
Just finished another autocross event today. Normally, I never bothered to use launch control since there were tight corners so close to the start. Today, I decided to give it a shot and I finally have the answer to the question "What is the minimum travel distance required to use Launch Control again?"
The answer: Very little distance! We had a short course this week, ~35-40 second range, I used launch control 5 runs in a row with the only driving in between runs being the time on course and driving back to grid, probably just over a quarter mile. Effectively, a drag racer could use launch control every pass. I also found out it's very quick to engage. I pulled up to the start with the trans in M1, DCT and Sport buttons. Holding the brake at the start, and to launch I just slammed on the gas and immediately took my foot off the brake. The car didn't move until the revs reached launch revs (does not take long, obviously) THEN launched, even though my foot was already off the brake. On another note, my car was parked with the engine off for 2 hours before my heat. I took it easy for 1 run to get the temps up, and was able to use launch control for the rest of the runs. I didn't try to use LC on the first run. Took 1st in class D-Stock again today and people are starting to comment on how well the car is doing in stock form on run flat tires. I absolutely love it. It needs nothing!
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait |
08-23-2010, 05:26 AM | #2 |
253
Rep 1,334
Did the flag icon come up when you nailed the accel to the floor while holing the brake? There should be no delay once you let off The brake if it's done correctly as its similar to slipping a manual clutch... U get tire squeal!! Congrats on placing 1st!!
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
08-23-2010, 05:27 AM | #3 |
102
Rep 1,552
The flag icon came up every time. There was a delay because it was still revving up to launch RPM. Basically just a split second delay, equal to a manual car with the clutch in revving to launch RPMs.
Basically: 1. Foot on brake 2. Quickly floor gas pedal 3. Immediately release brake as soon as you touch gas pedal 4. Transmission keeps clutch engaged as RPM rises to launch 5. Immediately launches as soon as 3500RPM hits Instead of keeping both pedals pressed, then releasing the brake to launch.
08-23-2010, 05:41 AM | #4 |
102
Rep 1,552
Video from today:
08-23-2010, 11:12 AM | #5 |
plasar
24
Rep 385
Drives: M3 Vert
Wow, congrats, awesome YouTube vids, and thanks for sharing.
I could really see different lines around the 180 degree turn that you have to brake for mid-course. Your last run did look quickest. BTW, did you trounce that yellow Vette that we see at the end of the vid in the parking lot? |
08-23-2010, 01:46 PM | #7 | |
102
Rep 1,552
It was surprisingly close though! Z06 on Hoosier race tires: 36.397 Factory Stock 135i on Run Flats: 36.557 I ran a 36.209 in fun runs at the end of the day, with a passenger I got faster every run and I really think if I put my best sections all together in a run I would have broken into the mid to high 35s. I thought I was at the limit of my tires on my first 3 runs which were 37.8, 37.6 and 37.5 but since another D-Stock class car ran 37.1 (on Hoosier R Comps!) I had to just go for it. Knocked off a full second on my last run for 36.5 when I kept the pedal floored through the slaloms. I was really surprised with how stable and completely neutral the car handled. I still think it does not need a stiffer front sway bar for stock class at all. I'll officially trounce that vette z06 next event, I promise The biggest surprise of the day: My Stock 135i was faster than all 9 STU cars!
2023 Supra 6MT - Deposit and Wait Last edited by MarkR171; 08-23-2010 at 07:21 PM.. |
08-24-2010, 12:23 AM | #8 |
31
Rep 1,917
Thanks for the vids. Excellent view to see the quick and hard launch the car performs. I'm guessing that's the Aloha stadium parking lot? Looks familiar from all the flea market shopping I've done.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
08-24-2010, 12:27 AM | #9 |
102
Rep 1,552
That's the one. The only legal venue on the island since the track closed a few years back (poor maintenance and lack of funds from the owners)
08-24-2010, 09:22 AM | #10 |
31
Rep 1,917
Where was the previous track?
08-24-2010, 10:54 PM | #11 | |
890
Rep 7,047
However, in a timed 1/4 mile, you'd want to keep your foot on the brake, press the throttle to the floor, revs rise, when the lights blink to green, release brake. In a 1/4 mile timed run, you'd blow the light using your above posted method. #4- clutch is kept dis-engaged |
08-25-2010, 01:17 AM | #12 | ||
102
Rep 1,552
08-26-2010, 08:43 PM | #13 |
14
Rep 235
Just curious, how many miles were on the car when you first used launch control? I hit 1200 today and was excited to try it out, but I can't get it to work. I'm 99% sure I did the right procedure. I could just feel the car trying to move forward everytime I gave it any gas and no flag appeared.
08-26-2010, 08:55 PM | #14 |
102
Rep 1,552
If there was no flag icon, LC didn't activate. My first one was right around 1250 miles. Remember the car has to be warmed up to allow you to use LC, and a minimum of 6.2 miles (that day, not necessarily that trip.) 2 of my runs with launch control were after the car was sitting for around 45 minutes with the engine off.
The full procedure: - Stop the car - Press DTC button once so "DTC" comes up on dash - Press Sport button - Move lever left to S1 - Click Downshift paddle to switch to M1 - Brake - Gas to full - At this point revs will increase and flag icon appears - Release brake to launch
08-26-2010, 09:02 PM | #15 |
14
Rep 235
Ah do you need to push the gas pedal all the way down? That's the only thing I didn't try..I was afraid if i did that and it didn't activate then I would be sitting there spinning my tires looking like an idiot or I might damage something. Does it matter what order I activate dtc etc.? (surely not)
08-26-2010, 09:30 PM | #16 |
102
Rep 1,552
It shouldn't matter. In between runs, my car is parked in Park with DTC still on. so that's already changing the order.
The car won't let the revs go up while the brake is engaged unless launch control is engaged, so don't worry about pressing the gas and brake at the same time until you see the flag. Again, make sure you've driven ~6 miles and the car is warmed up (~235-240 degrees on the oil gauge.) Also, your tires will spin and squeal a little so don't be alarmed when it happens
08-26-2010, 09:38 PM | #17 |
14
Rep 235
Okay I'll give it another shot tomorrow if I get a chance, this time giving it more gas. It was definitely warmed up after a 2 hour trip! Thanks for the tips.
08-27-2010, 12:29 PM | #19 | |
102
Rep 1,552
Maybe removal of the alignment pin for ~2 degrees camber but not sure if I want to bother with that.
09-04-2010, 11:44 AM | #20 | |
Rep 2
Lauch Control
I switch off the Traction control Move the lever to sport Pussh it forward Step on the brake Push the throttle It goes to 1300rpm and no flag no nothing I then release the brake and it seems for a second as if it gears down and the it goes. Is Launch control in all the cars My salesman tells me that I can only use it from 2000 km onward ???? |
09-04-2010, 12:02 PM | #21 |
Rep 2
Lauch Control
09-04-2010, 02:00 PM | #22 |
102
Rep 1,552
Read your manual. It states very clearly how to use it, and that you can only use it after 2000km.
