BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      08-16-2010, 06:58 PM   #1
Dave07997S
721
Drives: 2020 Ford Mustang GT
My exhaust setup..
I just bought a very slightly used OEM X pipe that I plan on modding by cutting out the OEM primary cats and going with the Turner Test Pipes. To prevent the emissions light going off I want to do the Akropovic Delete R or software. To be honest I am a little resident about the software. I did the Turner shark injector on my 04 M3 to delete the rear 02s on that car and had no issues.
I'm going to run the OEM rear section for now until I decide what mufflers I want to run. I lean normally toward Borla..had them on my 04 M3, my 997S and next inline will be my E92 M3 ZCP. I heard Drews car and I thought it sounded great with the Gintani setup.
Tell me what you guys think...doesn't mean I'm going to change my mind but still like to hear what others feel. Please keep it constructive, as I know opinions are like arse holes..everyones got one...
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk
      08-16-2010, 07:25 PM   #2
a burrito
Drives: Urus, 958.2 TTS, 997 S
Hey Dave, SteveK here from 6 speed.
From the exhaust setups you have heard on the e9x m3's, what do you think your tolerance to drone would be? I've heard a full gintani race to a handful aftermarket muffler only setups. Almost all of them sound badass but a lot of them drone because of the piping running through the belly of the car.
I know you ran a pretty loud setup before with the awe cats + x51 + borla so it seems to me you want a setup where you will be heard but the great thing about our 997's was that there was little to no drone.
Personally, I'm thinking of running the akra evo no R or the Gintani 2 x 2 pipe with the akra rear. Let me know what route you end up going with!
Peanut Butter Chunky
      08-16-2010, 07:37 PM   #3
MrLiu
yeeeeeeeeeeeee
Drives: E90M3, G55k, E55
steve you have way too many posts on m3post
      08-16-2010, 08:33 PM   #4
Dave07997S
721
Steve, you know..I'm not to worried about drone. I heard my setup with the OEM mufflers and there is no drone. Since I am keeping the rear 200cpi OEM cats and the resonators that should do a lot to alleviating any drone. The Borlas do drone on the E92 M3 but not that bad. The M3 with its 3.85:1 gearing won't see 2250-2500rpm to much.
Dave
      08-17-2010, 02:38 AM   #5
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
I think the Delete-R is super ghetto. here's why: It just sends a CEL reset every few minutes. If you get a CEL for anything, you will never see it, and you will never pass OBD-II readiness tests. The latter doesn't really matter for anyone who doesn't need to smog their car, but it can be a pain for state inspections, depending on where you live. I think it's a bit more booty that if a CEL comes on, it'll just get reset...
      08-17-2010, 03:37 AM   #6
TheKosherStogie
TheKosherStogie's Avatar
Drives: 08 M3 DCT AW/Red
Dave07997s congrats on the new car...seen you on 6 speed for a bit. Enjoy
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2
ACS - 1:49:6
WSIR - 1:30:6
      08-17-2010, 10:52 AM   #7
Dave07997S
721
From my understanding the Delete R still allows other CELs and only removes the rear 02 sensor fault. I'm not really worried about about smogging the car for at least 5 years.
Dave
      08-17-2010, 11:40 AM   #8
kitw
kitw's Avatar
471
Dave
That wasn't my understanding, since you can't send a signal to reset a specific fault indicator.
      08-17-2010, 02:18 PM   #9
Dave07997S
721
Just got off the phone with Turner Motorsports..they told me that the Delete R just stops the code for the rear 02 sensors from lighting up the CEL. Also that the diagnostics for the rest of the DME will still be active and will show up a fault and cause the CEL light to illuminate.
Thanks for the heads up I will get to the bottom of this. If this is the case than I would probably keep the primaries in place and just go with a new Xpip after the primaries.
Dave
      08-17-2010, 03:39 PM   #10
kitw
kitw's Avatar
471
I am almost 100% sure Turner is wrong. OBD-2 doesn't allow you to stop certain codes, you can either turn off the light (by deleting all the active codes) or you can completely clear all the codes... but not individual codes. Both will cause the readiness checks to fail.
Like I said, in CA, it doesn't matter. You won't need to get your car smog inspected until 2017.
      08-17-2010, 09:11 PM   #11
Dave07997S
721
I have left some messages from people who know more about the DeleteR, your point is quite valid though and understand where you are coming from.
I'm not worried about the readiness codes as I wouldn't smog the car even in 2017 with the modded xpipe, slap the un-modified OEM pipe back on and be done with it.
Thanks for the advice.
Dave
m3post
