BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      07-19-2010, 07:10 PM   #1
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
Corsa exhaust install
Installed my Corsa exhaust last weekend.
The installation was really easy. When I first snugged everything up, the mufflers were crooked, vertically. Turns out that you can rotate the midpipes to line them up, and I got them nice and tucked up towards the bumper and perfectly even. Just a matter of loosening both clamps.
Other than that, it fit really well. The welds are mostly really nice (except for a really messy resonator weld on both sides, it looks a little sloppy) and the build quality, at least on mine, seems really good. I hear a lot of stories about the Corsa exhaust not lining up and I think they need to do a better job documenting the adjustments.
- If it doesn't line up side to side, you can loosen the middle clamp and slide the exhaust in and out to line them up. Mine lined up perfectly with the pipes all the way in, but there is 1/2" each way of adjustment there.
- If it doesn't line up vertically, you just need to loosen both clamps (the midpipe to catback clamp and then the clamp in the middle of the corsa) and rotate the pipes. The hangers work fine with about 10 degrees in either direction, which gives about 1/2" each way of vertical alignment too. Maybe more.
Sorry about the blurry pictures, but you get the idea. The biggest downside is the looks. The Sedan exhaust is a little different from the website pictures in that the tips are shorter and the Y pipe from the muffler is custom built instead of the coupe version being what looks like an off the shelf Y. I kinda like the sedan's tips better, but there isn't much difference.
The only thing I don't like about it are two things: The tips are a little bit small (I like the magnaflow tips better). The other thing that bugs me a little is that the canisters hang down a bit too much, I wish they'd tucked them up a bit more. But, it's not that bad. I may paint them black if it really bugs me later on.
So far, pros and cons:
Pros:
- Sounds GREAT, it's the perfect exhaust volume for me.
- completely shuts up when you want it too
- sounds exotic and higher pitched, with a varying tone and some interesting frequencies
- Fitment was great, with a lot of adjustability
Cons:
- Tips are a bit small
- Canisters hang down too much
- not the cheapest exhaust in the world (although not bad at $1699 retail, I got it for 20% off during UUC's sale)
Hope that helps your exhaust buying decisions. Honestly, I was never going to buy a UUC exhaust again after all the problems I had with the System*U and the Twin canister exhaust on the E36... blah! But, I guess Corsa makes good exhausts and UUC just puts their name on them.
The video attached shows the exhaust from both inside and outside. It starts out inside the car with the windows down, through a little normal driving and some hard acceleration. Then, I put the windows up and get on an expressway, and you can see it doesn't drone. I then stuck the camera on the bumper so you can hear it from the outside.
Hopefully it gives you a good idea of what it actually sounds like.
[u2b]<object width="1280" height="745"><param name="movie" value="http://www.youtube.com/v/z2Xv_m908kQ&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/z2Xv_m908kQ&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="1280" height="745"></embed></object>[/u2b]
(Video is still processing, the quality will improve, although there really isn't a whole lot to see)
Here is a link, because the stupid video is still processing and the embed isn't active yet:
      07-19-2010, 07:15 PM   #2
Nate@IND
BimmerPost Supporting Vendor
Nate@IND's Avatar
2868
Drives: BMW
Props on the new system. Yep I have always said they need larger tips!
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      07-19-2010, 07:30 PM   #3
SleepyE90
SleepyE90's Avatar
Drives: Bavarian
Sounds great but the aesthetics of the mufflers turn me off.
The canisters are too bulbous and hang too low, the tips are too small (let alone not being true quads), and the price is a bit high for just a pair of steel mufflers.
If the canisters were smaller or tucked up, and the tips were redesigned, then I would buy this exhaust right away. The sound is definitely top 5.
Just my 2 cents
      07-19-2010, 07:59 PM   #4
M3 Esq
Automobilist
M3 Esq's Avatar
Drives: E70 X5, 911 GT3
Thanks for the write up. I also have been considering the UUC Corsa exhaust, as well as Dinan and AA, so this is very helpful. And the price is very attractive. It isn't the best looking exhaust in the world, but I don't think it looks as horrible. You said it has a high pitch sound - does it sound F-1 like? How much different (if at all) does it sound in person than on the UUC Corsa video clips? And how about drone? What does it sound like from inside?
      07-20-2010, 01:53 AM   #5
kitw
kitw's Avatar
471
dammit, I can't figure out how to get the stupid video to embed. It will answer all your questions. No drone at all.
      07-20-2010, 02:01 AM   #6
M3_WC
1040
Drives: M3
My friend has the same exhaust, but he had the cans ceramic coated black prior to install. You can't even see that cans, looks great.
      07-20-2010, 02:11 AM   #7
kitw
kitw's Avatar
471
Nice! did he send it out to jethot or something?
I actually had really good luck with BBQ paint on a previous exhaust...
      07-20-2010, 02:15 AM   #8
kitw
kitw's Avatar
471
Just my 2 cents
I agree with your criticisms, but my first priority was sound, second was fitment, and 3rd was asthetics. I figured that to equal the first 2 and better the 3rd, I'd be spending a lot more money The other choices in that price range were the Remus (way more money when you factor in buying connecting pipes) and not nearly as cool a sound... The Agency power (no E90 version).
I tried the Magnaflow as well and it was more domestic V8 sounding than I wanted. Didn't want a Meistershaft, as I hate companies who rip off other's designs. The Borla was my other choice, but it doesn't sound as cool, although it looks nicer. (although I still don't like the tips... and I have had a horrible time with Borla fitment on a few other cars)
Anyway, thanks for your feedback, I'm happy and hopefully when I paint the cans, they won't be so obvious.
      07-20-2010, 03:26 PM   #9
SleepyE90
SleepyE90's Avatar
Drives: Bavarian
I just saw the video from inside the cabin. NO DRONE! (from what I can hear) Honestly, as stated by another poster, when you do paint the cans they should pretty much be invisible. But I have heard that either painting or powedercoating exhausts doesn't last very long, you should look into ceramic coating.
It sounds great and I agree with your priorities
Enjoy!
      07-25-2010, 11:44 AM   #10
sly1types
432
Drives: F80M3 and E46M3
Sounds amazing! great vid
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104
E46 M3
F85 X5M
https://www.instagram.com/fastmacm3/
      07-25-2010, 12:47 PM   #11
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
danggg it sound really good. how much?
BTW, did you notice your emergency button inside is flickering. Take a look in the video.
      07-25-2010, 01:19 PM   #12
nusevad
O! So Sour!!
nusevad's Avatar
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
its because the light is a LED, cameras have a hard time capturing LEDs and that flicker shows up.
o and exhaust sounds great
      07-25-2010, 02:45 PM   #13
JCtx
258
Drives: No BMW yet
Sounds great but the aesthetics of the mufflers turn me off. The canisters are too bulbous and hang too low, the tips are too small (let alone not being true quads), and the price is a bit high for just a pair of steel mufflers.
Cans look like crap indeed. I thought nothing could look worse than stock, but I was wrong. Way wrong .
      07-25-2010, 08:17 PM   #14
M3 Esq
Automobilist
M3 Esq's Avatar
Great vid. It sounds like a cross between an american V8 and F-1 and has a very high pitch at WOT. Also, I didn't hear any drone in the cabin while cruising. Congrats!
      07-25-2010, 10:28 PM   #15
kitw
kitw's Avatar
471
Retail is $1699, I got mine during the 20% off sale UUC had. a UUC dealer should be able to get close to that.
      07-28-2010, 09:59 PM   #16
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
i think slightly larger tips would definitely take it up a notch.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      07-29-2010, 11:50 AM   #17
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
the muffler hangs low but it doesnt look any lower than the stock exhaust. my bastuck exhaust hangs almost as low as well. although it has bigger tips.
as long as fitment and sound is good, i think its alright.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      11-04-2012, 10:38 AM   #18
mkiv808
42
Drives: 06 E90/Cayman S
Sounds great in the video. I wonder what's louder, this or Bastuck. Seem to be 2 of the only no-drone exhausts out there.
2009 BMW M3 E92 6M AW/FR
Eibach Springs + H&R Front Sway + LUX AE + LCI Taillights + BMW Performance CF Spoiler + Bastuck Clubsport Exhaust
      11-04-2012, 12:48 PM   #19
m3an
m3an's Avatar
39
Drives: M3
Also check out Supersprint. Excellent exhaust that is pretty loud with 0 drone.
      11-04-2012, 12:59 PM   #20
PhillyNate
ENTHUSIAST
PhillyNate's Avatar
Drives: 2010 Porsche Cayman
Decent sound. Hating the canisters. Very few exhausts look good from the back on this car.
"what I'm driving here...is an ending." Jeremy Clarkson
2010 Carrara White Porsche Cayman 6mt
2014 Whiteout Toyota GT-86 6mt(Sold 05/23/15)
2011 Alpine White BMW M3 6mt ZCP Coupe(forced retirement 06/06/14)
2008 Alpine White BMW 328i 6mt Coupe(retired 06/21/11
      11-04-2012, 01:18 PM   #21
Sales@Evolve
92
Drives: Slow
Exhaust STIG is at it again!
Thanks for the review.
      11-04-2012, 01:29 PM   #22
flanast
flanast's Avatar
Drives: e92 M3
Me too. In ceramic satin black it looks and sounds great.
m3post
