07-10-2010, 12:51 PM | #1 |
Rep 18
Rolling your fender?
Hey guys whats up. I need to get my rear fenders rolled for my new tires and rims, but I cant find anyplace to get it done, I live in north Jersey, 10 minutes from NYC, can anybody help me?
Also, Ive been to 3 shops and no shop can mount my tires because supposidly they're too low profile? does that make any sense? |
07-10-2010, 01:54 PM | #6 |
Resident Kerbalnaut
477
Rep 10,703
You'll be rubbing, even with an agressive roll and cutting.
Any decent tire shop should be able to mount those tire sizes tho. |
07-10-2010, 02:31 PM | #8 |
aka 1013MM
1253
Rep 9,545
you will need to cut or shave the fenders, there's no other way. I have et 45 all around and I had to roll all 4. get them cut or negative camber to be safe. either way you need to do some fender work.... et33 is way too aggressive.. .
07-10-2010, 02:42 PM | #9 |
Resident Kerbalnaut
477
Rep 10,703
Do you has the 8.5 upfront and 9.5 rear? I was looking at those but was borderline on the fitment
07-10-2010, 02:43 PM | #10 |
Resident Kerbalnaut
477
Rep 10,703
Yeah they are super agressive for this car. Sub et 45 really doesn't fit all that well
07-10-2010, 04:22 PM | #12 | |
aka 1013MM
1253
Rep 9,545
OP- try 215 and 245 tires then do a roll or cut. see how that fits. also depends on your drop too.
07-10-2010, 04:25 PM | #13 |
Resident Kerbalnaut
477
Rep 10,703
I'm super sorry to thread jack but do you rub on the front wheels or the rear?
07-10-2010, 04:56 PM | #14 |
aka 1013MM
1253
Rep 9,545
dont be afraid of fender rolling guys! if you get someone who knows what he or she is doing then you will be 100% fine.
anyway i have 235 up front so that might be the problem why im still rubbing a little. i might switch to 225 next time.... i'm fine with my setup now.
07-10-2010, 06:10 PM | #16 |
aka 1013MM
1253
Rep 9,545
front will give you problems. just go stagg. its what our cars need anyway..
with that much tire i would recommend camber but thats $$$
07-10-2010, 07:12 PM | #17 |
129
Rep 559
Drives: ///M3
I had my fenders just slightly rolled to fit a 17x8.5 et 44. I has them done at Camber-toe by Matt. He did a great job and I would recommend talking with him. The shop is just a little ways outside NYC in long island.
Tim
M3 6MT SmTo/CS ZCP
135i MT JB/CR ///MSport - Gone |
07-10-2010, 11:45 PM | #18 |
Rep 18
what does et 45 stand for? sorry im not great with tires and rims. This is all i know:
My stock configuration was: 245/35/18x8.5 rear 215/40/18x7.5 front My new configuration is: 255/35/18x9.5 rear 225/40/18x8.5 front whats the difference? and how do you know if it will rub bcuz there's mad space between my tires, and i was told the tires would stretch more in that setting so they would run more low profile. Can anyone explain? |
07-10-2010, 11:54 PM | #19 |
Resident Kerbalnaut
477
Rep 10,703
Heres a good explaination of wheel offset (what et 30 or et 45 means)
http://www.tirerack.com/wheels/tech/...jsp?techid=101 |
07-10-2010, 11:55 PM | #20 |
Resident Kerbalnaut
477
Rep 10,703
On the stock wheels there is a lot of extra space to deal with and you won't have any issues with those size tires. I run a 225/40 front and a 255/35 rear on my stockers.
But on the aftermarket wheel that you're talking about those sizes will create issues |
