KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
05-25-2010, 04:17 PM | #1 |
121
Rep 1,198
ZCP ? - will the 265/35 on the rear work on the front?
Pretty sure the answer is no but would be a lot cheaper to move the rear tire to the front (add a 10mm spacer) and put a 285/30 on the rear. Any thoughts/opinions?
BC
'15 M3, '16 911 Turbo S Cab
05-25-2010, 05:49 PM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
That sounds like a good idea, but it may rub.
05-25-2010, 06:27 PM | #3 |
Critical Care Anesthesiologist
482
Rep 8,828
Drives: SMB F83
it may rub the strut or the back fender liner.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
05-25-2010, 07:13 PM | #4 |
yodog
197
Rep 5,025
It will rub when turning near full lock, but if it's for tracking or if you can live with this then go for it.
The 285/30 in the rear will look NOTICEABLY smaller than the front.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
05-25-2010, 08:20 PM | #5 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
yeah go with 265/30 not 35 in front. Im doing 275/35/18 in front, so...yeah
285/30/19 should be fine behind, as long as u do 265/30 front |
05-25-2010, 10:47 PM | #6 |
201
Rep 4,318
Some additional thoughts... I've got 275/30 up front and it fits but rubs slightly on the outer fender over big bumps (and rear part of front fender liner on full lock.) The 265/35 will obviously be narrower so that will help but the 35 aspect ratio in that width means the tire is almost 1" taller than what I am running (1/2" taller than the stock 245/35). I think that will be tough. Then again I am running AD08s which have a very square shoulder compared to the PS2. How much drop is dialed into your GCs? Camber?
Also note that with 285/30 out back you would be 1/2" shorter compared to the 265/35 front, which is the opposite stagger/wedge to stock (stock 265/35 rear is 1/2" taller than the 245/35 front.)
GT3 RS | Desperately seeking the next great M car...
05-25-2010, 11:02 PM | #7 |
121
Rep 1,198
Yeah I knew this was wishful thinking....
I'll either go with a 255/35 and 285/30 or 275/30 and 295/30 combo.... Thanks! BC
05-26-2010, 02:26 AM | #8 |
80 Deep, We All Eat!!!
66
Rep 643
+1, this is my current set up. Just barely rubs up front for me tho. I actually changed from 285/30 to 285/35 in the rear cause the 30's just bothered me wayyy too much. The rubbing up front is not bad.
