05-20-2010, 09:07 AM | #1 |
75
Rep 1,179
E92 M3 manual - a bit clonky?
Hi
test drove an M3 today with 13k miles and it sounds very mechanical when slotting into gears 1 and 2. Is this normal? Compared to my 330 (E46), it took me a while to perform a really smooth gearchange from 1st to 2nd and 3rd to 2nd. Does the diff make noise on full steering lock? What sort of noises / feel should there be pls? Cheers |
05-20-2010, 09:11 AM | #2 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
The M3 certainly is a very 'mechanical' car if that makes sense - especially when cold. The engine is louder and the transmission seems noisier. I had test driven the 6MT transmission before deciding on DCT and without starting the 6MT vs. DCT debate, I feel the DCT is far better suited to the current M3 than the manual box. I too found the clutch/box quite heave and clunky in the first 2 gears whereas I gel'd with the DCT box almost instantly.
If I was buying another i would be DCT every time and would not consider a manual one, but hey, it's horses for courses and everyone has different tastes! Have you driven a DCT based car yet, if not, you should before you decide |
05-20-2010, 11:52 AM | #3 | |
75
Rep 1,179
I'll be buying a manual car..... end of .....sorry. |
05-20-2010, 05:20 PM | #4 | |
17
Rep 290
I think gear changes can also be a bit clunky sometimes on the DCT as well if you are moving at a slow pace |
05-20-2010, 07:50 PM | #5 |
58
Rep 954
There's like 1/2 a second pause when shifting from 1st to 2nd.
11 335is, KW1, M3 bits and what not
08 M3 Sedan 6mt, loaded, modded to the bone Old: 04 M3 SMG |
05-21-2010, 12:58 AM | #6 |
Rep 116
There shouldn't be any 'clunking'. I would avoid that car or maybe just get a DCT.
'08 M3 AW/6MT, Eisenmann Race, BBS CH-R 20" / '04 M3 SMG / '09 GTR |
05-22-2010, 06:53 AM | #9 |
Rep 46
clunky + diff sound on full lock
Mate
this sounds suspiciously like the problems I had in jan with car I had off a friend (financed from BMW) with the option to purchase. Clunky gearbox........... manual grating sound on full fight right lock - front slip differential The car was in for the 13k service and the garage refused to acknowledge there was any fault till I took the chief engineer out for a quick spin the the car park and reproduced the noise at will. BMW stoke agreed there was a problem options were 1. low steering fluid - not so 2. Probs with front slip diff - maybe if the cars been abused / tracked 3. Gearbox .......... Enough to put me off. Waited for a few months and go the car i wanted if you check my posting............AM3 Newbie! Say this car wouldn't by anychance be a white E92 with red leather 13k miles jan 58 reg with 57 plate? Crewe Bluebell have a nice one I'm told A |
05-23-2010, 05:07 AM | #10 |
75
Rep 1,179
No it's not that car. There is no grinding but there is clunking which I have now been informed is quite normal.
The car is in warranty anyway so if there is a problem it will be fixed. Car has never been tracked and has just had a service at BMW. |
05-23-2010, 05:24 AM | #11 |
342
Rep 3,574
yah the M3 6M it's the smoothest out there.. gets annoying after a while.
2015 Porsche 991.1 GT3 2015 F80 M3 -- Individual; Space Grey |
