BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > UK
      04-17-2010, 02:09 PM   #1
wafik
wafik's Avatar
United Kingdom
225
Drives: F80 M3 ZCP / R56 JCW
Eibach lowering springs for M3 e93 with EDC...
Hey guys, I think its time to lower my car now...been on my mind for ages!
I want to go with the eibach springs...however i gave EDC and all the springs for the e93 M3 dont mention EDC and all have the same product code...So the question is - does it work with both non EDC and EDC cars?
Eibach Part Number: E10-20-014-18-22
Any help appreciated
BMW F80 M3 ZCP DCT | Individual Atlantis Blue Metallic | Extended Leather Opal White | CCB | M Performance Exhaust
Mode Carbon GTS Front Spoiler | Mode Carbon Trophy Rear Diffuser | Mode Carbon M4 Spoiler
      04-17-2010, 02:35 PM   #2
hugehead
hugehead's Avatar
United Kingdom
9
Drives: E90 M3
would of thoughts they do as the EDC is just oem adjustable damper and not the spring .
I installed the Eibach lower springs on my E60 M5 with edc without any probs if that any help to you
      04-17-2010, 04:25 PM   #3
chrisburns
chrisburns's Avatar
12
Drives: M3 CP Individual Mexico blue
Works fine, I fitted mine myself and have EDC and as above done the same with my E60 M5 as well.
      04-18-2010, 06:45 AM   #4
Neil McRae
BMW Motorsport
Neil McRae's Avatar
United Kingdom
235
Drives: BMW ///M4 F82 / BMW ///M5 F10
2020 BMW M5 CP  [0.00]
2015 BMW M4  [10.00]
Im going to lower with the edition springs.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White
      04-18-2010, 07:56 AM   #5
alpina527
United Kingdom
60
Drives: 2008 E92 M3 DCT JZB/FR
Edition springs are the same length as standard.
      04-18-2010, 01:20 PM   #6
Ant Man
United Kingdom
75
Drives: E92 M3 Individual Edition
Before you go ahead and remove all the suspension travel and bugger up the handling, pls read the various technical threads on the US suspension site section.
      04-18-2010, 03:04 PM   #7
chrisburns
chrisburns's Avatar
12
Dunno why you think that ?
I can assure you the handling is just fine running eibachs, they lower the car around the same as the BMW performance springs do so are you saying that BMW have buggered up the handling as well?
I have read the thread you are referring to as well and still stick by the fact the eibachs are fine.
TBH the above is a pretty silly comment IMO.
      04-19-2010, 05:51 AM   #8
stephengreen
stephengreen's Avatar
Drives: e92 monte carlo
Why is an edition model 10mm lower than standard then?
      04-19-2010, 02:09 PM   #9
hugehead
hugehead's Avatar
United Kingdom
9
Drives: E90 M3
Talking
+1 .....Eibach are one of the best suspension manufacturers out there
      04-19-2010, 02:11 PM   #10
alpina527
United Kingdom
60
Because the dampers have their platforms 10mm lower
      04-19-2010, 02:13 PM   #11
ss134
ss134's Avatar
United Kingdom
230
Drives: F80 M3
Correct about the M3 Edition springs being 10mm lower than standard but the EDC on Edition cars has also been updated to suit. Dont know the effects of running these springs on non Edition EDC.
      04-19-2010, 04:14 PM   #12
wafik
wafik's Avatar
United Kingdom
225
Thanks guys...If i lower it will be eibach....but i still dont know if for the e93 its only one type available for both EDC and non EDC?
      04-19-2010, 04:28 PM   #13
ss134
ss134's Avatar
United Kingdom
230
Drives: F80 M3
The Eibach springs listed at the bottom of this link are stated for the E93 M3 incl EDC!
http://www.**********s.com/product.a...ach_E90_E92_MW
      04-19-2010, 04:29 PM   #14
alpina527
United Kingdom
60
The EDC Eibachs and non EDC Eibachs are the same.
E93 uses different springs to the E92, but are still the same on EDC and non EDC versions
      04-19-2010, 04:36 PM   #15
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Both Eibach and RD Sport springs are perfectly fine for EDC-equipped M3s.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      04-20-2010, 03:48 PM   #16
Ant Man
United Kingdom
75
Which M3 springs are you refering to? Eibachs lower the front by 20mm and therefore double the drop of the Edition models.
The purpose of the springs is to hold the car up at the required ride height, allow sufficient movement above and below this point, resisting excessive body roll and allow the wheels to follow the road surface. Spring travel is thus a very important part and the if there is not enough travel, the spring bottoms out. Effectively that corner of the car ceases to have suspension.
If this happened when cornering or braking hard it could be very dangerous.
The M3 front suspension has 0.5" of travel before hitting the bump stop. The bump stop has been dyno'd and acts progressively over the first 1" of compression. It's resistance then shoots up at which point it is not acting like a spring.
The front M3 springs are rated at 160lbs, meaning it takes 160lbs of force to compress the spring by one inch. With two adults in the car you are already eating into the available spring travel.
So with the Eibachs you are already riding on the bump stops, yes the springs are stiffer by ~22% but only at the maximum compression (as they are progressive) and this will potentially create a worse handling car.
Below are the threads to read
http://www.m3post.com/forums/showthread.php?t=370301
http://www.m3post.com/forums/showthread.php?t=360300
http://www.m3post.com/forums/showthread.php?t=343880
      01-23-2013, 05:45 AM   #17
sylonien
sylonien's Avatar
United Kingdom
114
Drives: M3
I want to lower for looks but can't help but think that I will ruin the comfort and forcing the dampers to work harder than they need to and that surely BMW knows what they doing after all the time they took in researching.
      01-23-2013, 06:29 AM   #18
S65V8
*_*
Drives: ...
+1, there's simply no escaping that the car's dampers will wear out faster with aftermarket springs of any kind. Eibachs being the least intrusive of the bunch due to its more conservative drop.
Also, keep in mind the car's dynamics change slightly with springs that inherently "rake" the car forward to compensate for the front fender gap. This could be avoided with a sleeve kit from KW or GC.
      01-23-2013, 12:11 PM   #19
sylonien
sylonien's Avatar
United Kingdom
114
Drives: M3
I've been trolling through many threads / forums on the Competition pack and some say it's 10mm lower springs, and some say its' the same spring and confirmed by the dealer that they are the same springs? and only the mounts or some other parts that lower it?
Also is it possible to code it the new EDC functions with the '07 cars?
Ie. is it possible to install the springs / or whatever part that has to lower the car and not mess up the shocks?
      01-23-2013, 02:21 PM   #20
hugehead
hugehead's Avatar
United Kingdom
9
Drives: E90 M3
fit the springs and changed the bumpstop to a E36 one as it higher to compensate
      01-24-2013, 03:08 PM   #21
sylonien
sylonien's Avatar
United Kingdom
114
Drives: M3
Is that what you did?
      02-02-2013, 05:22 PM   #22
hugehead
hugehead's Avatar
United Kingdom
9
Drives: E90 M3
No I have the spring sitting in garage , as my car is still relatively new (only 13k miles on the clock ), I am waiting till when i need to change , then have them fitted along with the E36 bumpstop.
that is what most members do when fitting ebach spring as the suspension travel will be minimise by the lower springs
ps ...spring do not effect the EDC, so no need to code the car
m3post
