04-01-2010, 11:46 AM | #1 |
BimmerPost Supporting Vendor
548
Rep 5,695
▀▄ eas | ATI ePod Steering Wheel Gauge Pod - e9x M3
The ATI ePod is the first of its kind, a revolutionary gauge pod design capable of housing 52mm gauges, while featuring full rotational positioning for custom viewing angles. This patent pending design is clearly setting new standards in pod technology.
The ePod replaces the original steering column completely and integrates dual 52mm gauge pods. All cables are hidden with the Cable Management System. Each is color and texture matched to ensure the cleanest OEM look available on the market! Note: Gauges are not included. Product Features: Rotational positioning for custom viewing *unless noted otherwise Houses 52mm gauges Integrated Cable Management System (CMS) Precision injected molded construction High impact ABS plastic Quality fit and finish UV additives for protection Simple and easy installation Models Supported 2006+ e9x 3-Series including M3 http://www.europeanautosource.com/pr...oducts_id=3140 |
04-05-2010, 11:06 AM | #3 |
11818
Rep 23,187
kind of a trick idea dont know how that would look though?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
