BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      03-25-2010, 04:24 PM   #1
Bisan
12
Drives: 2008 M3 & 1988 M3
Will 15 mm extended bolts work with 18mm spacers?
As the title says?
Trying to play around with some ideas...I already have 18mm spacers with extended bolts but they are silver...
Want all black bolts on my new wheels, but need 12/15 mm spacers front rear but might run an 18 mm spacer in the back to see how i like the look....
Any idea if the 15 mm black bolts that I'll buy will work with the 18 mm spacer, or if it'll be safe enough to use?
thanks
Brand wise, I am either picking up the Macht s. from EAS or the turnermotorsport spacers...
      03-25-2010, 06:48 PM   #2
foosh
foosh's Avatar
Drives: 2008 M3 E93
Originally Posted by bisan View Post
As the title says?
thanks
I have no clue what you're talking about with 15mm lug bolts, but you're not even close for 18mm spacers. 24mm length is OEM (e.g. no spacers).
Read the link below. You need 42mm shaft length with 18mm spacers. You can also get your black lug bolts here.
http://www.rogueengineering.com/Merc...t_Code=WSPACER
      03-25-2010, 10:52 PM   #3
swamp2
swamp2's Avatar
Drives: E92 M3
Originally Posted by foosh View Post
I have no clue what you're talking about ...
Pretty sure he meant he has bolts that are +15 mm compared to stock and if those will work with 18 mm spacers. This would probably work just fine but I don't think I would do it. Just get the right bolts.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      03-29-2010, 08:08 PM   #4
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
or are you referring to the bolt length that came with the 15mm spacers and are asking if they are fit for using 18mm spacer? eg. bolt is not technically 3mm short?
if that is the question, i would not do it. bolts and wheels are too risky to mess around with. try and get the proper size.
      03-29-2010, 11:41 PM   #5
MShao825
Go Terps!
MShao825's Avatar
53
Drives: 2009 SSII/FR E92 M3
I had Macht Schnell 12mm/15mm spacers and the extended lugs were the same size, were they not?
      03-31-2010, 10:56 PM   #6
akina335
60
Drives: a car
when i bought 18/15mm spacers from Rogue Engineering the lugs were the same size for both.
      03-31-2010, 11:44 PM   #7
Krozi
Krozi's Avatar
Drives: 2008 E92 ///M3 Alpine White
Yea same here...bought mine from EAS..
2008 E92 ///M3 Alpine White//Fox Red//6MT//
Florida Bimmer - Join us on FaceBook!
      04-01-2010, 12:14 AM   #8
Bisan
12
thanks guys! Exactly the confirmation I needed....
cheers
      04-01-2010, 12:24 AM   #9
ilidon
ilidon's Avatar
Drives: F13 M6
2009 335i  [7.00]
just paint it with acrylic black paint and you're good to go.
F13 ///M6 SMB/SO
E92 ///M3 AW/FR- Sold
E92 335i MB/BLK- Sold
[IMG]http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578
m3post
