ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      03-08-2010, 12:40 PM   #1
S2peed
23
Drives: 07 Black Z4MC
TC Kline D/A Coilovers (settings & alignment)
Hello,
Wondering if I can get some input on what settings you guys are running with your coilover setup.
I just installed TCK DAs w/ camber plates and I need to get an alignment, what camber & toe settings will suit best for street? during track days I can slide the camber to -2.5.
Thanks!
      03-08-2010, 06:48 PM   #2
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Originally Posted by S2peed View Post
Hello,
Thanks!
I recently did the same install and set the front alignment per the TCK instructions
http://www.bimmerfest.com/forums/sho...7&postcount=74
At -2.0 degrees front camber I have 0.06 degrees toe in and 7.7 degrees caster.
At maximum -3.5 degrees camber for the track the toe is at 0.1 degrees out.
In the rear I'm running -2.0 degrees camber and 0.18 degrees toe in.
I have the ride height at 25.25 inches front and 25.75 inches rear measured from the bottom of the side rail to the ground; you want at least 0.5 inches of front rake.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      03-09-2010, 12:42 PM   #3
S2peed
23
Thanks Jim
zpost
