BMW E60 5-Series Forum | 5Post.com
Go Back   BMW E60 5-Series Forum | 5Post.com > BMW 5-Series (E60) Forums (2004 - 2009) > General 5-series and M5 (E60) Forum
      03-02-2010, 07:26 PM   #1
interlago_m3
Drives: M3 E92/ E60
2008 M3  [10.00]
06 E60  [0.00]
Need battery replace
My 06 E60 show low battery. And it just pass the 5 year warranty. And i call to dealer, it charge $400+ to replace. Did any one know where can i good deal for battery??
      03-09-2010, 04:40 PM   #2
Bajzashop
Drives: 2009 335i
I think if you have aaa they would do it for under 200. And they come out to you.
Im sure you can also buy a battery and install it yourself.
      03-09-2010, 07:59 PM   #3
interlago_m3
Drives: M3 E92/ E60
2008 M3  [10.00]
06 E60  [0.00]
i checked from other place, they carry replacements battery. Some of them are under power. And finally found 95R from autozone for $179
      03-19-2010, 07:40 AM   #4
B767capt
Drives: 2024 X5 40i
The reason it's so expensive at the dealer is because they have to reprogram or rather reset the adaptive battery charging system when a new battery is installed. I just went through this with mine. Dealer quoted 500.00. After reading different forums, the reset is required so the new battery isn't either under charged or over charged based off the old battery data. I bought a new Interstate MTP-93 battery for 129.00 and installed it myself. I have an 08 535i. I also bought the Bavarian Technic program and did the battery adaption myself. My daughter has an 08 328i so this applies to her car too. Worth the investment. Clears codes and can read them too.
      03-25-2010, 10:25 AM   #5
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
there is a reason why the dealer charges a lot, but they will need to reprogram the battery for you
      03-25-2010, 04:34 PM   #6
B767capt
Drives: 2024 X5 40i
I reprogramed it myself.
      04-28-2010, 08:47 AM   #7
rjm
rjm's Avatar
Drives: 2008 528i/2007 328i Coupe
I just called 4 dealers in the DFW area for quotes on battery replacement on a 2007 328i.
1st dealer quoted $450
2nd dealer quoted $550
1st aftermarket BMW shop quoted $350
2nd aftermarket BMW shop quoted $180
All quotes were for original replacement BMW batteries with registration included.
All shops told me batteries must be registered to the car so the "smart alternator" would recognize the new battery and charge it accordingly.
      04-29-2010, 09:05 AM   #8
fnc
Drives: 540
You can install it yourself. Then drive over to a local shop and have them register the battery. This should save you some $$.
      05-10-2010, 07:29 PM   #9
interlago_m3
Drives: M3 E92/ E60
2008 M3  [10.00]
06 E60  [0.00]
I finally buy the battery from autozone for $180, and replace it @ home with my friend in 5 min ( quick & easy). But never reprogram for anything. And driver for more than 3 weeks, no problem at all.
      05-21-2010, 01:05 PM   #10
rjm
rjm's Avatar
From Motor Magazine:
Foreign Service
By Dan Marinucci | June 2009
"Vehicles are becoming increasingly self-aware with each passing year. It’s no longer enough to replace a battery when necessary. Many late-model BMWs also need to know when you replaced it.
Last month I discussed a timely trend in higher-end European electrical systems, the absorbed glass-mat (AGM) battery. This time I’ll focus on another one, relearning BMW charging systems after battery replacement. You read correctly—relearning the charging system!
First I’ll recap the AGM battery information. An AGM battery is more damp than wet inside because it isn’t flooded with liquid electrolyte like a traditional battery is. Also, AGMs are designed to be very low-gassing batteries. These features make them especially well-suited for locations inside the vehicle. Some higher-end European vehicles have an AGM battery somewhere inside the vehicle powering on-board electronics while a separate battery under the hood handles starting duties. Finally, fully recharging an AGM battery safely and quickly requires an AGM-capable charger.
Okay, let’s get back to those late-model BMW charging systems. First, the electrical system is so sophisticated that it tailors charging as closely as possible to both the type and the age of the battery. There’s a computer, which goes by several different names, that controls the alternator. Whenever you replace a battery, this computer really needs to know because it doesn’t charge a fresh battery the same way it charges an older battery. What’s more, this computer needs to know if you’ve updated a vehicle from a conventional battery to an AGM type; it charges the AGM differently than a traditional battery.
Second, the process of updating this alternator-control computer is called battery registration. You don’t absolutely have to register every new battery you install in these late-model BMWs. Ignoring the registration process after replacing a battery won’t trigger a DTC or turn on the MIL. However, a savvy BMW specialist warned me that skipping the battery registration process can dramatically shorten the life of a battery in these vehicles, be it an AGM or a conventional battery. For instance, he’s diagnosed cars on which a new battery didn’t even last a year because it wasn’t registered! The charging system could shorten the life of an unregistered battery by charging it too aggressively when it’s cold; it also could shorten the life of an unregistered AGM battery by overcharging it, he said. To say the least, premature battery failure can be aggravating for the customer and embarrassing for you and your shop.
Third, several problems can cause premature battery failure. On a late-model BMW, skipping battery registration can be one of them. Don’t gamble; always register a new battery on any BMW equipped with MOST Bus—a single-line, fiber-optic ring network BMW introduced in the early 2000s. Typically, the easiest way to identify a vehicle equipped with MOST Bus is to look for iDrive. In turn, the quickest way to spot iDrive is to look for the fancy LCD control display screen up on the instrument panel. Among other things, this display screen shows the driver climate control functions, navigational info, entertainment system controls, etc. (To my knowledge, the lone exception to this is the 2006 3-series cars without iDrive, which still use the MOST Bus network.)
Here’s when MOST Bus appeared on the most common BMWs your shop would encounter:
•2002 for 7-series (E65/66 vehicle platforms);
•2003 for 6-series (E63/54 vehicle platforms);
•2004 for 5-series (E60/61 vehicle platforms);
•2006 for 3-series (E90/91/92/93 vehicle platforms);
•2007 for X5 series (E70 vehicle platform);
•2008 for X6 series (E71 vehicle platform).
Fourth, registering a battery is easy but it requires a scan tool that communicates effectively with these BMWs. If you want to service more of these vehicles, shop for scanner updates or a new scan tool that will do the job. The screen capture on page 10 from an AutoLogic scan tool is an example of one of those you’d see during the battery registration. You also could look up battery history on this same screen. Notice that the first entry is “Last battery replacement (km)”and the reading is 0.00. Meanwhile, all the remaining entries are the same value of 528,392 km (about 328,000 mi.). These readings show that if someone has replaced this car’s battery, he did not register it.
One BMW specialist pointed out to me that sometimes you can quickly check to see if the car’s got the original battery in it. He said that BMW traditionally stamps the battery’s manufacturing date on the negative terminal. The date stamp shows the week first, then the year. For instance, “42 05”indicates the 42nd week of 2005; “33 07”would mean the 33rd week of 2007. If the date stamp on the negative battery terminal is fairly close to the vehicle build date, then it’s extremely likely that it’s the original battery.
Look at the screen capture again. The BMW ace told me that if the battery had been replaced and registered correctly, the number in the top box or window would be 1.00. Next, the second entry there would be the kilometer (km) reading when the new battery was registered. Then, the rest of the entries in those little windows would show the vehicle’s then-current km (odometer) reading.
Last but not least, you need to know where to find the registration process within the BMW system. A BMW-capable scan tool initially shows a variety of windows or boxes on the screen. Sometimes you’ll see a window labeled BATTERY REGISTRATION REPLACEMENT; that choice is a no-brainer. On the 7-series cars, choose the Power Module (PM) window to access battery registration. Otherwise, the most common way to reach the battery registration is through the window labeled DME (Digital Motor Electronics). Just choose the appropriate window and then follow all the prompts.
Hopefully, these basics will save you some headaches. After all, customer expectations here are likely to be much greater than they are for many other vehicles you repair. If nothing else, you know what’s required if you decide to subcontract this task to a BMW specialist."
      11-30-2010, 09:21 AM   #11
mekanik
Drives: BMW E60
Need Help. Anyone done the battery swap and programmed it without going to the Dealer in DFW area? Please let me know what to do, my battery need to be replaced and i don't want to pay huge amount to the dealer.
      12-05-2010, 06:52 PM   #12
Rennsport1
Drives: E92328iSportPkg.PremPkg.CWP.MT
Question Dead battery could use some advice...
So I have a dead battery(my car is an '07 328i with 33k miles). It's Sunday night, so most shops are closed. I did call BMW Roadside Assist and was was going to have her towed to the dealer but I changed my mind and canceled the call. My car is parked in my office parking lot, in "my spot" which is away from possible door dings, and only about 500ft from my home. I thought maybe I should do some research first before having the dealer put in another OE battery and charging me some nutty amount.
Any advice ?
I am also considering lightweight batteries such a Braille if they're reasonably priced and I can get one soon. And what sort of cost am I looking at ? and any installation tips ?
Thanks in advance for any helpful info,
R.S.
R.S. '11 Jet Black/Tan Dakota E90 N55 335i SPORT/PREMIUM/NAVIGATION/BUTT WARMERS. Previous: '07 E92 328i Alpine White/beige,SPORT Pkg.,Prem. Pkg.,CWP.,no Nav.,6MT..
Your D/FW Realtor since 1995
5post
