01-18-2010, 09:04 AM | #1 |
Crack Addict
84
Rep 759
Can't get homelink to work.
Hello,
I've tried to get my homelink system to work. I did everything the instructions said, and it will not recognize my remotes. I have an Inellicode gate opener for my gaurd gate and a Genie garage door opener. The homelink will not detect either of these. Am I missing something? Thanks, - Dan
2009 - Titanium Silver - Steptronic - 135i - Nasty
01-18-2010, 10:13 AM | #2 |
381
Rep 2,926
Drives: Cayman GT4, 135i
does the homelink program the code IE blink rapidly when the code is accepted? If the code is accepted then you just have to have the garage door opener "learn" the homelink code
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
01-18-2010, 10:26 AM | #3 |
31
Rep 1,107
call roadside assistance, they can talk you through it. My dad had trouble setting it up on his because of the rolling code setup.
01-18-2010, 10:36 AM | #4 | |
Crack Addict
84
Rep 759
It just blinked slowly, which means it isnt picking up the signal.
01-18-2010, 10:45 AM | #5 |
76
Rep 5,970
I live in a building with a community garage, and I havent' been able to get mine working either.
On top of that, I think I've screwed up the opener trying. Sometimes the regular remote doesn't work any more no matter how many times it's pressed. Then if I hit the Homelink button on the mirror that I was trying to program, nothing happens, but the next press on the regular remote opens the door. It doesn't do it all the time, maybe one in 8 or 10 trips. I've got to get it figured out though, because it's not just me that's having problems. I saw one of my neighbors have to get out of the car and press the button on the wall the other day. I've got to sneak down there in the middle of the night and get a ladder up to the reciever to see what model it is so I can figure out how to reset it. |
01-18-2010, 12:04 PM | #6 |
133
Rep 1,416
Drives: M-Sport 128i, 328xi, 3.0CS
I think that there was a mention of pushing a button on the opener itself, not the remote.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
01-18-2010, 12:07 PM | #7 |
Crack Addict
84
Rep 759
the instructions say to push both in close proximity, and i did. And the light was blinking slowly and did not blink rapidly. Which means it didnt pick up the signal.
01-18-2010, 12:35 PM | #9 |
satch
39
Rep 1,040
The website?
I found the website helpful.
My garage openers have the rolling codes so before the homelink would accept and sync I had to press program on the openers themselves and run back to the car and press the homelink button once more. Check here: http://www.homelink.com/programming/programming.taf |
01-18-2010, 01:24 PM | #10 |
76
Rep 5,970
01-18-2010, 01:28 PM | #11 |
146
Rep 582
Still can't get mine to work either. Tried the learning process on the homelink site with no luck.
Current: 2021 BMW X3 M40i
Previous: VW GTI, Tesla Model 3 LR, Mazda MX-5 RF, Ford Mustang GT (x2), Mazda 3, BMW Z4 sDrive35i, Acura TSX, BMW 135i, Acura TSX, Honda Accord Coupe V6, Acura RDX, Pontiac GTO 6.0, Pontiac Grand Prix GTP |
01-18-2010, 01:57 PM | #12 |
Rep 42
Dan, I'm having the same problem on mine. My complex has some off-brand opener and I can't find any program button on it (I don't know if it is rolling code or not).
Let me know if you figure it out. |
01-19-2010, 09:35 AM | #13 |
27
Rep 476
It took me a lot of trial and error to get Homelink to work in my car. The key was to put one of my garage door opener remotes RIGHT UP AGAINST the bottom of my rear view mirror. It didn't work at all if I held it at the recommended 4 to 12 inches (or whatever it was). Once I got Homelink in the mirror to learn my garage door opener remote, it was a snap to get the actual garage door opener to accept the Homelink in the mirror.
01-19-2010, 02:37 PM | #15 |
46
Rep 332
On some openers - make sure that you're close to the actual motor itself rather than just using the remote. Some motors have a link button that lets you sync up with the motor and the car. I had to do that with mine.
01-19-2010, 04:01 PM | #16 |
Crack Addict
84
Rep 759
So I have to be close my garage door eye and have the remote button pressed while my car recognizes it? My garage door will be flipping out thats for sure!!!
01-19-2010, 04:17 PM | #17 |
15
Rep 86
Your Homelink system might be bad. Mine worked for about 1 year then just stopped. I am fairly certain there is no signal being transmitted. Resetting doesn't help. All the signals show the code is recognized and stored, but no go. I reset and reprogrammed several times and tried all three buttons. The original battery remote works every time and the Homelink in my nine yr old E46 does as well. I haven't taken it in to the dealer yet.
01-30-2010, 07:05 PM | #18 |
60
Rep 300
I am having the same problem. The opener in my building's garage is ancient, this thing has dip switches inside to set the code. Is it possible the homelink is just not compatible with older remotes? The receiver on the door itself looks like its from 1975, no "learn" button on it whatsoever.
01-30-2010, 08:17 PM | #19 | |
31
Rep 1,107
01-31-2010, 12:19 AM | #20 |
60
Rep 300
Yeah, I tried that, but no luck. I did some searching, and it appears I need a homelink adapter that costs around $60. I'll have to talk to the board and see if they'll allow me to install it in the garage. There are other cars in the garage that I'm sure have homelink units that can't be used either, so it might be worth it.
02-10-2010, 11:04 AM | #21 |
Rep 14
Homelink Issue: solved
We had trouble getting our homelink to work, too.
The engine has to be running, not just the key in the ignition. Re-set the unit for 20" by pushing down the outside two buttons until the LED flashes rapidly. Then, place the existing remote right next to the controls (not 4-12" away as in the manual. Push one of the homelink buttons at the same time as the remote. The LED will flash rapidly after a few seconds. Done! Homelink only works when the engine is running. Other problems we’re trying to solve (just 3 days of ownership): 1. Trunk not opening w/ remote 2. Understanding the climate controls 3. iPod system works OK, but why not a jump drive inserted into the USB slot?? Hey, we did figure out how to remove the cup holder extending into the passenger area (just pull hard towards the passenger door direction). One step at a time……… |
02-10-2010, 11:41 AM | #22 | |
Feuertrunken
58
Rep 635
Crimson-Coral Red |Walnut | iDrive | Premium & M Sport | Heated seats | PDC |CA | Premium hi-fi | BMW SSK & PE | BSH OCC -
Deposit 7/15/2009 - Ordered 9/18 - Production 9/23-30 - Euro Delivery 10/17 - Shipped 11/13 - Oxnard 12/8, Oregon 12/24 & home on 12/30 |
