12-05-2009, 04:49 PM | #1 |
221
Rep 2,339
How can I run new wires into the front doors?
I was trying to get started with my install today by test fitting my new adapter rings and running all the wires from the trunk to the speaker locations when I ran into a major roadblock. The wiring going into the front doors is terminated with a large connector right at the point where it exits the footwell. The connector totally blocks any other wire from coming through the rubber tubing. I need to get 2 speaker wires into the front door. Has anyone else ran new wiring into the door?
Since I ran into that roadblock, I decided to just try to prep the trunk for the amp install. Here's some pics of the connectors I installed on the factory wiring so I can tap the signal and run it into my Zapco amp. It very similar to what was posted by another user using 4-pin disconnects to tap the front HU out signals. Disconnects installed with OEM wiring reconnected: Closeup of disconnects with OEM wiring connected: OEM wiring disconnected and adapter with Zapco Symbilink connector plugged in:
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
12-07-2009, 10:34 AM | #2 |
8 tracks of madness
62
Rep 2,735
I can't see your pics from work but with a molex the easiest thing to do is look for an empty area and drill it out on both halves of the molex then run your wires through. That's what I did on my GTI. Not too bad a job, just time consuming. The other option is to tap into the OEM wiring from the trunk. With the amount of power your mids and tweeters will actually draw you don't need anything larger than the OEM wiring anyway. That's what I'm going to do.
12-07-2009, 11:07 AM | #3 | |
221
Rep 2,339
12-07-2009, 12:27 PM | #4 | |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
that way you can take the single pair as an input and run short wires to the mid and tweeters |
12-07-2009, 12:39 PM | #5 | |
8 tracks of madness
62
Rep 2,735
That's exactly how my GTI is. Just look for some unused space and drill. Yes, you'll destroy some pin locations but if they're empty you're not using them anyway. Bummer there's only one set of wires into the door though. It would be so much easier if they ran it active from the factory. Curious to hears what he says though. Once again I'll be using what you find to my benefit. He's running an active setup. |
12-07-2009, 01:45 PM | #6 |
221
Rep 2,339
Like QS said, I'm running active which means no passive crossover network. All the crossover duties will be handled by the DSP in the Zapco amp.
01-10-2010, 08:38 PM | #7 |
221
Rep 2,339
I managed to get the car fully wired to the trunk including squeezing 2 new speaker wires into the doors. As VP mentioned, there is room under the factory connector to squeeze the wires in. Since I was concentrating so hard on getting it in, I didn't even think about taking pictures of how I got it in there. I just wanted to share that it is possible. I used standard CL3 16-2 speaker wire from home depot since that is the wire with the thinnest jacket I could find. I don't think you would be able to get a standard car audio speaker wire in there since the insulation tends to be a lot thicker than typical home audio speaker cable.
Now the last thing to do to complete my install is to modify the sub enclosures to accept the SWS8s and install the front door speakers. Then there is the whole other can of worms called tuning that I need to explore. But I will have some help from an experienced friend with that one.
