12-02-2009, 06:37 AM | #1 |
Rep 25
TPMS
Hi everyone.. Sorry for my English, i’m French!!! LOL..
I just installed my winter tire on my car, and now the TPMS sign came on… I just wonder how the monitoring for this system work on a 135I. Cause I don’t have the rigid valve installed on my mag. So I guest the signal is not on the valve ?? how it’s work ?? I'm asking that, cause last winter i had no sign, and same thing when i put back my summer tire.. Thank |
12-02-2009, 08:51 AM | #2 |
12
Rep 123
in canada there are no sensors in the tire, you just need to go into the manual and follow the reset routine. At least that is the way it is in the 128i. My understanding is the sensors are only used in the US, our cars apparently use one of the brake sensors to measure the wheel rotation and uses that to detect changes.
12-02-2009, 05:23 PM | #4 |
49
Rep 759
Drives: 128i Coupe 6MT
Yeah, the sensors are in the brake assembly on our cars, so no need to buy wheels/tires with them. Strange that it's having problems, it probably just detected an imbalance with the new tires and is thinking that one of your old ones is deflated. Reset and let us know how it goes!
12-02-2009, 06:19 PM | #5 |
8
Rep 74
your winter tyres must be 0.5 of your original tyre size (not the radius or the width...theres some other mesurement you need to take in consideration for which i forget the name) for the ABS system not to detect an imbalance that would cause the TPMS light to come on.
12-02-2009, 06:37 PM | #6 |
Rep 25
Thank every one.. so i follow the easy step to re-initialize the reading... start the car, find the TPMS light, press 5 secondes & the reset mark will appears, everything is fine now..
Thank again. holy.. not the same car with me Hakipalla 5 with stud, so much noise & you losse grip... i will have to check my breaking distance on the road... |
12-04-2009, 11:44 AM | #7 | |
12
Rep 123
